Heated seat problem
jdowens1
Ford Senior Master Technician
Montana
I have replaced dozens of heated seat elements and haven't seen any repeat failures.(knock on wood) not of same pad anyway. I have for example replaced lower heat element and three months later replaced backseat element. I like to replace both seat pads since they are in series with each other but sometimes Ford's wonderful warranty doesn't allow it.
jdowens1
Montana
I do like the thought of Ass Dragging next time customer comes in with heated seat inop I'll ask if they are ass dragger!
swoop1156
USA
My seat back and seat bottom have separate heating elements... At least the two-stage button seems like it turns my back portion off and leaves the bottom on. Maybe it's so low the back feels like it's off?
jdowens1
Montana
I don't believe the Raptor has a back element.
FSM
I haven't been in the Raptor but I was reviewing the wiring diagram to make sure and it doesn't show the raptor only having one element. I suspect it still uses two in series but I could be wrong. I'm just going off wiring diagram.
FSM06
Colorado
Yep, I believe you are correct jdowens1. Looks like it does. Like you, I have not seen too many repeat failures, but lots more seat cushions than backs for sure. I like your theory as far as BIRDS is concerned. Maybe he is a back dragger rather than a butt dragger....................
FSM
BIRDMAN
BIRDMAN
Birdministrator
Boston
FSM
It did the same thing too, it's def the seat element...it got hot as a bitch under my thighs and I did think to myself SHIT not this again...sure enough I heard the click a minute later and it shut off.
jdowens1
Montana
Bird, did you get your seat fixed yet? was it the same element or the back seat element? just curious if you got faulty part or a different pad failed.
J DAMAGE
NJ
Not the best write up, but will try to explain, and pictures to help.
.(Done with out removing seat from truck).
1st---Use switches to set seat at it highest hight, for working/hand room.
2nd---Remove the seat belt cover,lightly prying from top and popping it off.
3rd---Remove the seat control switch assem, prying from top, then working your way around assem, " CAUTION" Dont pull to hard, you have to disconnect the switch plugs, rear first, front last, not alot of slck on wires, just enough.
4th---Front section there is a T20 torx screw ( REMOVE ).
5th---Rear of seat, unzip both sides a little, on the rear left side corner there is a 7mm screw, ( REMOVE ). NOTE you can remove the seatbely torx to get side panal out of your way, or just slack the seatbelt, your choice.
6th---On the switch side and front of seat, you will see a plastic J-channel stiched to the seat cover, pull down and release from side bar and front brace, NOTE there is one on the right side next to center console, I did not release that one, "CAUTION" WATCH YOUR FINGERS, the metal on the seat frame is sharp as all hell, (opened my finger up, if i pulled would of been going for stitches, lol.
7th---Slowly pull seat cover up around seat, taking caution not to pull to hard, there are 3-hog rings hoding the seat cover at the center seem, and velcro holding the cover on the left,right and rear of cover.
8th---2 niddle nose pliers are now needed, first rotate the hog rings so you can see there overlap, once there take your 2 niddle nose pliers and spread open the rings, take caution not to tear the felt flap with the plastic edging stitched to the seat cover.
9th---Now you should be able to move the seat cover out of the way enough, to work, SLOWLY start peeling the heat element, working your way around untill its removed, NOTE-some come off easy, some don't, you can use a heat gun to loosen the glue and peel, or you can just cut the old wires off and install the new element on top of the old, your call.
10th--When installing the new element, make sure its in the correct postion, and you have the section where the hog rings are, tucked into the foam channel good, you don't want to much tension on the element when recrimping the hog rins, thats where the wires are for the front and rear sections of the element feed each other.
11th---Now just reverse the prosses to complete.
Sounds like alot, but I just wanted to explain everything your gonna see, total time took me 1hr 20min, from start to finish, along with pic's. TOTAL COST $23.00, ordered element from TASCAPARTS.COM
