2024 Heated Steering Wheel Works Poorly
Bmitch
Long Island NY
Hey there all. The heated steering wheel in my 2024 F150 Raptor does not seem to work at all most of the times.........BUT it has definitely come on where I felt acceptable level of heat maybe 4-5 times since I got it in September. So I don't think I have a low setting issue like this post discusses, my problem is intermittent. I'll have it looked at when I bring it in for my first oil change. Just wondering if anyone else has had this issue and what to expect from the dealer.
automoto
New Jersey
Mine is somewhat spotty too even after increasing temp with Forscan. This morning driving to work it was 28* outside and i kinda sorta felt the heat from the wheel, other days i gotta turn it off.
Bmitch
Long Island NY
I
Thanks........I have had times where I thought maybe it had a room temp feel when cold but I decided it was probably from my hand or the sun in one specific spot. Then like i said previously, i have definitely felt heat a small handful of times so I thought the room temp thing was def an anomaly. This is probably a stretch from Ford's engineers but is it possible that the heater is tied to the outside/inside temp and regulates how hot the wheel should get and maybe that needs some adjusting.
Bob M
Bmitch
Long Island NY
Hey RaptorFun-
I tried to get some info for you. Looks like for the 2024 MY, Ford moved the adjustment to a new module called SECM-7C5 (Steering Effort Control Module). Here is a link to a spreadsheet that looks like the correct info for your rig.
I will try to link you to the exact spot in the document but if it shows up weird you can go right to the link. When you click on this link, if you look at the very very bottom, you will see all of the modules listed on one line at the bottom. You can take your mouse or your finger if you’re on an iPad or phone, and scroll until you get to the SECM-7C5 module and then go down to line #56 where the steering wheel temperatures begin - SECM-7C5 Line 56 is low, line 57 is medium, and 58 is high temperature. (These are noted in Celsius)
Also, below that you will see lines 60 to 64 that will allow you to change how many minutes you want your steering wheel to stay hot before it automatically turns off. You can also set it to stay on if you would like.
Good luck brother - If I can help you with anything else, let me know!
Here is the link to the Google Docs spreadsheet -
Hey there @Crow68 I responded to this post later on asking about what seems to be an intermittent heated wheel on my 2024. Does what you posted above mean there are low medium and high settings for the heated wheel? I have only really felt the heat 4-5 times since September. Several other times I was just not sure if it was even warm or if it was from my hand or the sun. I will be asking the dealer to look at it when I bring it in for an oil change I was just hoping to know the answer beforehand. Thanks!
Crow68
Modesto, CA
Hi Bmitch-
I think @RaptorFun figured it all out. It looks like they did some changes to the module setup for the 2024 MY pickups. I am pretty sure he has all of the info on the settings that you need. If I recall, they are still setup in HEX format for different exact temps. If you cant get the details from him, let me know and I will try to help!
RaptorFun
Northeast Wisconsin
Hey @Crow68 …you are correct. I was able to get things sorted out with @hamster ’s help. Hope this helps:
Module: SCCM
Address: 724-06-01
Original Value: B000-0019-FB (95 degrees)
Make a change to the first value ONLY. Here are what the values equate to:
B=95 degrees
C=96.8 degrees
D=98.6 degrees
E=100.4 degrees
F=102.2 degrees
Since I reside in Wisconsin with cold winters…I changed mine to the maximum value:
Fxxx xxxx - -
hamster
Northern VA
Module: SCCM
Address: 724-06-01
B=95 degrees
C=96.8 degrees
D=98.6 degrees
E=100.4 degrees
F=102.2 degrees
Fxxx xxxx - -
I first changed mine to D and it was a waste of time. Now at F and no complaints.
Bmitch
Long Island NY
Module: SCCM
Address: 724-06-01
B=95 degrees
C=96.8 degrees
D=98.6 degrees
E=100.4 degrees
F=102.2 degrees
Fxxx xxxx - -
Hey @RaptorFun and @Crow68 ......Thanks for the info on this heated wheel issue gents. I am convinced that i have a switch problem or something other than low set points. Its been 10 degrees here on Long Island all week and my heated wheel works sometimes and doesn't others. Way less than 25% of the time. I've been trying to see when it does work but it varies. Sometimes it works when the truck auto started, sometimes not. I hit the button a few times this am turning it on and off and after driving 20 minutes it finally did came on. It is at a good temp when it does come on so i don't think that is an issue. I still don't understand what makes it come on on high, medium, or low though. I will have the dealer look at it when I bring it in for my first oil change soon and with this info I can at least speak intelligently with them. If that does not work, I will reach back out to this chat and maybe consider trying the Forscan app myself if its not too difficult and wont affect my warranty. Thanks again.
RaptorFun
Northeast Wisconsin
The heated steering wheel does not have a low…medium or high setting. It’s either on or off.
FORScan is not difficult to work with and will not void your warranty. You’re merely enabling or disabling features already present from the factory.
The only word of caution I can provide…as my FRF brethren have always stated…be certain to back-up the As Built modules prior to making any edits. If for some reason you need to revert back…you have a backup. It’s the first thing I do and it only takes an additional 20 minutes of your time. Also…take you time. Don’t work with FORScan if you’re crunched for time. The end result(s) is sheer bliss!!
