Try putting more tongue weight on your trailer by moving the buggy forward. You need to have more weight on the front than the rear....
"As he was driving it on..."
i ride my quads up on my trailer but only after i have it hooked on to the truck and the safety chains connected. as far as tailgate, you will probably spend the same on repairs as you could get a new one.
I suggest save your money on a hitch and buy a tailgate
OP, spend a few dollars and purchase a new coupler and bolt it onto the trailer tongue, they’re inexpensive. Insure you get one with a pin that when inserted prevents the coupler from being removed. Make sure you use 2 adequately sized safety chains to attach the trailer to the tow vehicle.
https://www.amazon.com/dp/B076XNS314/?tag=fordraptorforum-20
This is a good hitch ,but only available in 2 5/16
Drop it on and it locks, and you can see lock
Use the jack to lift it off
There is a reason pinto hitches are used
I avoid all trailers. Trailer tires are the worst tire sold, right after RV tires.
Want another one to avoid? Van with ladders all over the top. Seen those come off at highway speeds.
Another? The crackhead with 167 million pallets held on with one ******** his 97 F150. Seen those come off at highway speeds too. Dumb **** looked so surprised that they came loose when he hopped out to survey his wreckage. A couple asian POS sedans just drove right over full wooden pallets and kept rolling like it was no big deal. I managed to see both of them coming loose and avoided both the pallet guy and the ladder guy.
Thanks zombie killer
It's not a dove tail
But the gate itself is tall
Almost 6 feet
So the angle of approach isn't steep
you're putting enough force on the tailgate to uncouple the trailer and cause damage.
If you simply spend the $100USD for the stabilization jacks and have mounts added to the trailer, when you engage them, the trailer physically cannot end up being a lever any longer. At that point, you could probably use the trailer as a launch ramp.
It doesn't matter how steep or long the ramp is. you're creating enough force to unlatch the trailer. And loading a buggy on that thing at anything faster than a slow crawl is asinine and foolish. you arent overcoming some steep angle, so if you continue to do the same thing, you really made your own decision and should accept the consequences and damage.
