TeamFordRaptor
The spark knock is really getting to me. :mad2:
My motor mods are Volant CAI, Flowmaster 44 Catback, and now a Superchips tuner.
The spark knock hasn't changed so I'm going to switch to 91 octane fuel.
I do have a few questions for those who have knowledge on this:
1. How many tanks after I switch to 91 should i give it to tell a difference?
2. If that doesn't work is octane booster my last shot?
Im just totally perplexed on what to do about this problem. any suggestions?
The foreman at ford blames the CAI & Temp, the guys at 4Wheelparts thinks thats BS. JDM says its due to using 87 octane and if that doesn't do it the CAI needs a specific tune, superchips thinks its octane.
On a side note I was told that tuners are not really adjusted for a specific CAI and that the tuner simply notices a difference in air levels and adjusts accordingly. It has no idea if it's a CAI or a change in altitude or temp.
Those who suggest 91 or 93 octane, these are not applicable solutions for a spark knock. If there is a sprak knock with 87 octane, the problem will only increase and possibly become louder with higher octane (Higher octane, hotter ignite, louder knock). Octane booster again will only make the louder knocks, well, louder. Understandable if the engine is sluggish or you've added a supercharger or turbos, but with a Spark Knock, less is more. This isn't my or one mans opinion, this is Ford's and any intelligent mechanics knowledge. Got off the phone with Ford and 4 engineers just minutes ago.
The CAI does NOT need a tune. The computer still has the capability of reading the air flow regardless of stock or aftermarket. The computer then adjusts the mixture accordingly. Ford engineers have specifically designed this engine to run at a certain temp with air and fuel factoring in all these things.
The tuner has nothing to do with the knock as I'm sure everyone is aware also. The tuner is most cases would run smoother with 91 octane, but again the spark knock will only grow the more you add.
We are looking for a solution to the specific problem and I will post again when we nail it. Thanks!
