Driving in snow?
FordTechOne
Detroit
Just didn't think it would be as touchy as it is. Can I disable the ABS?
No, ABS is not a feature than can be deactivated. Are you running the OE tires at the recommended air pressure? If you stab the brake in snow in any vehicle you’re going to get ABS intervention. Mine handles the snow very well, if I drive normally ABS rarely even engages.
Badgertits
Ma
Select either normal or sport (if in doubt measure your balls) then 4A....then TC off, that is best way to actually “feel” what’s going on in the snow & still have grip & still be able to put as much power down as needed
F
Fordraptorrrrrrrr
Idaho
Running Toyo RT Open Country tires at about 37psi
The Car Stereo Company
here, on frf
i think it depends on the snow. if theres a lot of water content you are probably slipping on ice. we got 8 inches of snow last night bere in thornton co, but the snow here packs down to almost nothing so it not bad at all. in the sierras around tahoe 2 inches of snow packs to ice and you are slipping around everywhere because the water content is so much more, it packs to ice quicker.
goblues38
STL
yeah...stop hitting the brake pedal so hard
ABS is engaging because you are hitting the brakes too hard, or your tires are complete trash.
If you get into abs, you are not braking properly. manual pedal modulation will ALWAYS be more efficient stopping then ABS.
F
Fordraptorrrrrrrr
Idaho
Tires have a ton of tread left only like 6 months old.
I'll try what you said, just never seemed to have an issue in the snow driving other vehicles it seems.
goblues38
STL
Tons of tread mean nothing...if it is the wrong tire compound, they could be as hard as hockey pucks. And in snow, mud tires are horrible. Mud tires eject mud / snow so the treads are clean.
In the snow, you want your tires to hold the snow, snow on snow is what provides traction. not rubber on snow.
Snow rated tires have small sipes designed to retain snow for winter driving.
sipes
mud vs mountain rated
