Tin can rattle upon cold start and driving m: UPDATE not wastegate
SCAR911
Arizona
So It’s definitely not the wastegate. I did the recommended spring fix. Below is the video I took of the sound. It’s definitely in that area that’s creating the tin can sound. Any ideas?
Truck running ok? Almost sounds like lose turbo couplers. That's pretty substantial
Nex
RIP CoronaRaptor
Washington State
How many miles on your truck? Sounds like catalytic converters. On a cold truck, hit them with a rubber mallet. I bet they are broken and will rattle.
thatJeepguy
GA
Ive had this happen but my truck would intermittently stall due to restriction.
downforce137
In Diana
What happens when you rev? Kinda sounds like something hitting the flywheel. Maybe the starter isn't disengaging completely?
bruce7105
Central Cal
I just had the same problem it turned out to be in short muffler the piece that separates the two parts broke loose and sounded like a bunch of bolts in a tin can just to be sure it wasn’t the cats I cut it open. Sounded so bad and I thought for sure it was the cats. New SPD Trombone pipe and problem solved
patire19
patire19
NJ
how did you figure it out that it was that area making the noise?
