- Joined
- Dec 16, 2016
- Posts
- 18,109
- Reaction score
- 28,353
eco is a relatively loud engine, there’s a lot going on. Is it a problem or does it foreshadow a problem to come?
Interesting, that’s distinctly different though. Thats a quick grinding noise with a hard start/stop. Mine is a true rattle (sounds like all the 10mm sockets you’ve ever lost in a tin can being shaken) that slowly dissipates.Watch this.
Foreshadow in my mind since there’s no noticeable issues with power, boost, shifting, steering, AWD/4WD. Wild that it sounds so horrible without any noticeable performance impacts or codes.eco is a relatively loud engine, there’s a lot going on. Is it a problem or does it foreshadow a problem to come?
Please post what they find. Iv'e been chasing a very similar rattle that I'd swear is coming from the transmission area.Update: Finally traced rattle down to coming from inside the bell housing so they’re dropping the whole trans next week. Unfortunately I have one of those trucks that’s got some pretty bad rust (surface on frame/rear axle but exhaust is bad), soooo now we upgrade. Dealer will be installing new SPD SS downpipes + trombone mid as part of the repair so long as I provide them. It’s a 2019 with 40k so still under powertrain.
Will post updates in about 2 weeks. They won’t be able to drop the transmission until around the 24th/25th .Please post what they find. Iv'e been chasing a very similar rattle that I'd swear is coming from the transmission area.
sounds like my dealer everything is a month out i swear it feels like a drs office lolWill post updates in about 2 weeks. They won’t be able to drop the transmission until around the 24th/25th .
Now that is an odd problem on a stock converter.SOLVED
Turned out the torque converter was ballooning for an unknown reason. Swelling pushed everything out and was causing the flywheel to unevenly rattle on the spacer between it and the block. Here’s a pic of the spacer the tech just sent me.
