Muchmore
Hey man, you're lucky I know how to make it....Ok. We have non-ethanol here. Is the e50 better/cleaner?
Kinda knew it was higher octane# but never found out if the higher suger content b/c of the corn messed with anything. Always heard E85 was bad, dunno if it is true or not, like I said, never got any facts on itA quick search said something to the effect that straight E85 is between 100-104 octane and is about $1 cheaper then 93 so that’s a good cost savings. Lol
These show mixed values.View attachment 313532View attachment 313533
So what about the injectors? Are they an easy install as well? Injectors, colder plugs, and pump plus tune are everything needed.I heard the install for the HPFP is around a 20-30min job and then get a tune for E85 that adjusts the pump settings to accommodate the new pump and you are good to go. I am running a Goose E50 tune and it’s a mix of E85 and 93, truck is nuts on the E50.
To run E50 you need intercooler/colder plugs and a tune. To run Full E85 you need to add a high pressure pump OR injectors, if you have money burning a hole you can do both. Not sure how long a injector install is.So what about the injectors? Are they an easy install as well? Injectors, colder plugs, and pump plus tune are everything needed.
