F
full-race geoff
AZ / NJ
So @full-race geoff just to confirm, latest idea for the motor is Gen 3 block (including timing gear), worked over Gen 2 heads for the fueling system to work, and the best available (and compatible) oiling, cooling, and ancillaries…especially oil pump and dampener.
Correct?
Wild cards:
1) a/c compressor compatibility
2) knock sensors
3) oil pump modification(s)?
4) ?? What else?
Edit: My google-fu may be weak, but I can’t seem to find new 3.5 HO ecoboost motors from Ford; looked for short blocks, long blocks, and complete motors…nada from Ford.
I found tons of rebuilt ones from various vendors, but nothing new from Ford.
Any help getting pointed in the right direction to find a factory Gen3 long block as a starting point appreciated.
Edit#2: Nothing from Ford Performance, but found this:
And this:
…still searching for a Raptor (HO) spec motor
happy new year rob!
1/ you got my idea 100%: buy a gen3 complete engine new from ford, install Gen 2 heads and fuel system.
2/ there isn't much benefit to the "HO" moniker so Ford abandoned it with the Generation 3 3.5L engine... all 3.5L ecoboost generation 3 are the same spec. The part # for a Gen 3 complete engine is: NL3Z-6006-A -- tasca has it for ~$3700 (+1500 core).
3/ The current hold up / question marks I cant answer currently:
Oil Pump and Timing Gear: If anyone reading this is serious about beefing up your motors - email Boundary Pumps and let them know youre waiting along with me! They're a small operation and respond well to organic feedback and requests.
Knock Sensors: Will the Gen 2 computer freak out with Gen3 block using Gen2 knock sensors? nobody can answer this yet
A/C: The Gen 1 / 2 / 3 compressors all appear to share the same bolt patterns. Unclear if the Gen 2 AC lines have enough slack in them
everything else from motor mounts to head gasket to turbo connections to radiator hoses all appear to be 100% the same and good to go.
does the Gen 3 pulley fit the gen 2 and if so, could it be an “upgrade”?
Gen 3 pulley can physically fit the Gen2 engine and I'd consider it an upgrade over OEM! The incompatibility to be aware of is your Gen 2 block AC / belt position needs to move forward to line up with Gen 3 pulley. Of course if you don't need to retain AC this is a non-issue.
and now that im typing this, I forgot to measure if there's a difference in drive pulley diameter for the water pumps (i need to confirm)
Any higher rate DI injectors yet? I want to make the most on 93.
-Upgrading only the DI pump to a Nostrum or XDI + adding 1000cc port injector is the easiest compromise and straightforward to tune. At that point a boost-a-pump or a 2nd intank fuel pump should be in the cards to maintain fuel pressure
-Ive seen port injectors larger than 1050cc do not run well on this application. It seems like popping in a massive port injector should work fine but it doesn't. Most guys pushing the limits even on E85 end up switching back to the 1050s and are upgrading the DI pump
-It's complex to get an aftermarket DI injector tuned well. Also depending on your tuning setup I dont know any 3.5L with aftermarket DI injectors on Cobb (only SCT / HPT)
XDI makes a set that you can pair with their direct injection pump.
do you know of anyone using these? We have many happy customers with these XDI injectors on the 4 cyl engines. MPT says they've tuned inconsistently on 3.5L - some just "work" with the native SCT injector multiplier scaling, others were all over the place.
happy new year everyone!
RaceUV
Utah
happy new year rob!
@full-race geoff
I do not currently know anyone using them. I had seen them in passing and figured I would share the info. Personally I plan to use the FID1000’s that I have sitting on my desk, in tank DW400, and an upgraded HP pump (sourced from you guys at Full-Race). Speaking of fuel system stuff Geoff, do you have any experience with the DW400 and its PWM version that DW sells? Any better options for a single in tank pump that will do the job on e85?
P.s. I will definitely message Boundary and show some interest. My engine is old and tired. I know it will need a fresh engine at some point in the not so distant future.
Thanks.
91Eunos
Hill country, Tejas
… Oil Pump and Timing Gear: If anyone reading this is serious about beefing up your motors - email Boundary Pumps and let them know youre waiting along with me! They're a small operation and respond well to organic feedback and requests…
Emailed them, told them I’m ready right now to invest in a better oiling system for my truck.
As an aside, it looks like Boundary does do a pump, gears, and even a crankshaft sprocket for the ecoboost, so is the issue just a matter of them adding a dowel or was it something else?
Sorry if it’s already been asked and answered, don’t recall what the specific issue was that precluded using that setup.
And Happy New Year to you as well @full-race geoff … I’ll shoot you an email tomorrow after I call Tier1 to see where they are on rebuilding my transmission. I want to make sure you have some stuff in stock so I can pay for it, and grab it on my way there, or on the way back to Tejas.
F
full-race geoff
AZ / NJ
The OEM generation 2 raptor gets an impressive in tank fuel pump - In fact it outflows the dw400. FYI - The dw400 is best suited for generation 1 trucks.
I haven’t tried yet - but I’d say the next best option is something oem quality, brushless and pwm!
Yes, these are for generation 1 3.5L Ecoboost’s. Missing the dowel on the oil pump and missing the second row of teeth on the timing chain sprocket
F
full-race geoff
AZ / NJ
Does anyone have experience with the KHC front LCA kit? I was planning to weld plates on the LCA mounts and I found they offer a kit with 3 stages to heavily fortify the area: https://khcoap.com/products/gen-2-ford-raptor-slot-delete-kit
this is the stage 1, last bit of frame prep I planned on doing, would save me time having to fabricate:
Their stage 2 adds significant bracing to the forward mounts:
I'm trying not to add unnecessary weight to the nose of the vehicle, so the stage 3 is out for me
Is it a drop in replacement for a 2020 Expedition? Do you have a Ford part number? That sounds awesome!
It does fit the base f150, although I dont know if its a drop-in for an expedition. part # is HL3Z-9H307-F - lmk how you it works out if you do swap over
RaceUV
Utah
Thanks Geoff,
I will definitely get one of these coming in the next few weeks and report back with results!
Also, definitely looks like that plate kit is a solid option. Especially if they will ship you the kit bare so you can MIG the plates in place. Just my $0.02.
