downforce137
In Diana
Does anyone have experience with the KHC front LCA kit? I was planning to weld plates on the LCA mounts and I found they offer a kit with 3 stages to heavily fortify the area: https://khcoap.com/products/gen-2-ford-raptor-slot-delete-kit
this is the stage 1, last bit of frame prep I planned on doing, would save me time having to fabricate:
Their stage 2 adds significant bracing to the forward mounts:
I'm trying not to add unnecessary weight to the nose of the vehicle, so the stage 3 is out for me
It does fit the base f150, although I dont know if its a drop-in for an expedition. part # is HL3Z-9H307-F - lmk how you it works out if you do swap over
i have a few friends with various levels of this kit, and i know the KHC guys from several runs ive attended..
I think this is the best front end reinforcement system out there, and i plan on adding some of it to my own truck.
im trying to get them to make a pre cut frame plating kit for the frame, hes very good with making the CAD stuff into reality.
F
full-race geoff
AZ / NJ
I will definitely get one of these coming in the next few weeks and report back with results!
Generally the oem raptor pump is all that’s needed, hopefully it fits your expy
The brushless pump makes sense if you want to stay single pump without a boost-a-pump at the higher power levels. good info to read below:
Ti Automotive BKS1001 Brushless E5LM Pump​
Thank you for the confirmation, that’s pretty much exactly what I thought
100% needs to happen. I’ve been trying to order from rpg and getting nowhere
91Eunos
Hill country, Tejas
@full-race geoff something occurred to me as I was walking through the next steps on my truck where I’m trying to mirror your engine build, and had a question.
I still intend to order a complete Gen3 motor to get the timing gear along with other improvements, but could I also swap over the valve train? I know the intent is to use the SI valves, better springs (GSC I think?), and the Coyote follower fingers, but do the Gen3 heads already have the Coyote valvetrain?
In other words, does it make sense to pull my heads and have them rebuilt before I have the Gen3 motor on hand, or is it smarter to wait until I have the new motor and pull valve train parts off the new Gen3 head in addition to the timing gear (cam phasers, etc.) that would stay on the Gen3 motor after I swap over my Gen2 heads?
Edit: Also sent you an email re: stuff I’d like to snag from Full Race when I’m there in Phoenix picking up my transmission from Tier1 in a couple weeks!
91Eunos
Hill country, Tejas
Boundary pumps replied and said they are currently working on a pump and gears. They anticipate production by the end of the year. Good news.
I got the same email response this morning… sounds like they’re serious about getting going on something for the 3.5 ecoboost!
I offered to pre-pay for one even if it takes a year to bring it to market. I really want to do this one right and build in as much reliability and critical system protection as possible with this motor.
Buy once, cry once.
RaceUV
Utah
@full-race geoff
I just thought of a few things I figured would be good to discuss on here.
1. You mentioned the Gen 3 internals being better. Did Ford actually redesign the rods similar to the Gen 1 to Gen 2 coyote improvement? if so, is there a measurable weight difference like the coyote rods?
2. Is there any strength differences in the block itself from Gen 2 to Gen 3 architecture?
3. Do you know of any place that sells a deck brace by itself for the open deck 3.5 block? All I can see online are companies that sell entire blocks or short locks. It would be nice to be able to just purchase the deck brace and have a machine shop of your choice install it.
Thanks.
F
full-race geoff
AZ / NJ
Hey Rob - yes the Gen 3 heads already have the BR3Z coyote valvetrain. and you're correct that buying a gen3 longblock to swap heads gets you all the metal timing chain guides, latest tensioners, phasers, and coyote lifters/followers. This is the best off-the-shelf solution I can come up with to try and bulletproof the 3.5L valvetrain.
Using the SI valves and GSC springs with a headgames setup remains the recommendation when going the extra mile. The only thing beyond this would be 2016+ ford GT parts, however thats an entirely different price point and requires ford approval with a VIN #s
Yes, sending the heads out now would be the call. the Gen3 parts don't need to be on-hand until engine assembly.
you will not need any of the Gen 3 / Coyote valvetrain parts for the cylinder head preparation to be completed. Just the bare Gen2 heads is all that needs to get sent out
@full-race geoff
Thanks.
1. All 3.5L rods are the same - gen 1 / 2 / 3 they all share the same HL3Z-6200B connecting rod. I have not weighed them individually so maybe I am overlooking something (I am not an expert engine builder). this is overall a decent rod especially for $43 that ford sells it. of course its considered the weakpoint for most modern turbo engines regardless of mfg
2. Gen 3 blocks have additional webbing, debatable if thats a tangible strength gain. 100% without question Gen 3 cranks are stronger. also Gen 3 crank pulley does not self destruct like Gen 2 crank pulley
3. I do not believe a "deck brace" is beneficial for these engines. Ive had years and years of open deck aluminum block turbo experience and it is almost never been the weak link
I got the same email response this morning… sounds like they’re serious about getting going on something for the 3.5 ecoboost! I offered to pre-pay for one even if it takes a year to bring it to market. I really want to do this one right and build in as much reliability and critical system protection as possible with this motor.
Thank you!! I appreciate you all for reaching out on this.
F
full-race geoff
AZ / NJ
this was one of those rare weekends that I could set my phone to do-not-disturb and pump out work. THANK YOU RPG - they came through with the slotted front lca plate and frame doubler plate. I was about to move forward without plating and the package arrived just in time - thank you very much if you're reading this. I requested the slotted front LCA plates, and drilled them so I can use eccentric cams.
I drove into shop @ 6am saturday morning and pulled the bed first. Then we pulled the cab, it took 2 hours <<the flying wrenches cab pull youtube video is great btw>>.
This was followed by exhaust, driveshafts, engine/trans, fuel tank, brake lines and wiring harness. It all swapped over, can now tell you with certainty the generation 3 frame + axles is 98% plug and play.
**Rear driveshaft flanges are different** was the only oops surprise and luckily I had a gen 3 flange on a shelf already, need to swap it out this week. Minor drilling and tapping of M8 was needed for grounds and various harness tabs. ABS bracket needed an M8
Everything was examined closely before reinstallation and there were some problems. both motor mounts were shot (will post a photo to show). Replacing with Gen3 motor mounts - they are nicer looking, unsure if stronger? Also front diff bushings completely destroyed. I have a lot to say about this, will save for another post.
