full-race geoff
Sorry I did not do this yet (been focused on bronco raptor/ranger raptor 3.0 and 2.7 Ecoboost). Right now parts are piling up, and I need a solid 2 day wrench-fest to get things in a good place, hopefully early MarchHey @full-race geoff Did you ever determine if the Raptor R motor mounts will work on the 3.5 block?
Parts 1 and 2 in this diagram:
I believe this is the left-hand side part #: https://www.fordpartsgiant.com/part...bmodel=&extra1=&extra2=&filter=(r=1877;e=730)
And this one is the right-hand mount: https://www.fordpartsgiant.com/part...bmodel=&extra1=&extra2=&filter=(r=1877;e=730)
They look very similar, if not identical to mine, but would like to see one and measure first. Just wondering if you had the opportunity to do so yet.
The ford system shows the part as fitting 2022-2025 f150 soo I’d be surprised if it doesn’t fit up
That’s a great point. The hybrid variant might have some differences to the standard 3.5L worth exploringthe Hybrid variant. Might be worth looking through part numbers for differences.
Sadly my contacts that helped Full-Race with previous gen 3.5 projects left Ford during a mass re-structuring. As you’re probably aware they and many others left as part of a corporate mindset move away from ICE’s toward electrification. A huge amount of 3.5 eb knowledge and experience gone
Agreed that 800+hp warrants consideration of cylinder support. However ethanol and soft ignition can go a long way at safe power production. My only pushback to the CSS is the stock sleeve can still crack, it just won’t shatter (detonation typically). it may be a safer bet than a ductile iron sleeve or it might also create headaches with sleeves moving.That's all just a fancy way of saying, you only need it if you're losing head gaskets. The 3.5 does have a pretty large bore and bore spacing so it's not a bad idea if you're shooting for big power (800+).
Long way of saying 700hp is the reliable / safe ceiling I want to work toward and the stock open sleeve block should be fine with that.
Please let me know if he can do it? I still think a dummy solenoid may be necessaryI have MPT doing the tuning on my set up and I intend to have him attempt to find the tables in the tune file to shut this function off completely.
