What did you do to your Raptor today? (Gen2)
Sig Fanboy
WV
Are there any FRF members (giggity) close by that can reset via forescan for you?
Edit: or someone that can remote in and do it for you?
After I get my Devers installed, I may ask, I’d be willing to drive a couple of hours. I’ve be wheeling my Raptor regularly and my springs are starting to flatten out pretty good. The trail I run the most stuffs the drivers side the most, I’m now 3/4 of an inch lower on drivers side and in conjunction with recovery/ chase rack I’m slightly lower back to front. I guess I need to run my favorite trail from other direction to stuff the passenger side some. But it still rides nice, just getting saggy in the back. Some day I’ll do bypass like yours. I want to get some use outta my FFRS set up before diving into that rabbit hole.
cptnslo
denver
Yeah, I recently installed the Live Valve Fox Factory Race shocks. Wishing I’d gotten the 17-18 non live valve shocks and just deleted live valve with the module. I have no clue who around here could delete the live valves I took off. If I get those deleted I can keep them to use when my FFRS shocks need rebuilt.
Do you mean the actual live valve delete onto the shock itself? Based on the video I’ve seen on yt it’s easy enough to do at home.
Sig Fanboy
WV
I guess I don’t know exactly. I am a YT addict, so I’ll investigate. I think if you just disable live valve the shocks default to a stiff setting. The shocks I took off had sub 30K miles on them. They seemed fine, but while they are off I thought about getting them rebuild if I found a place nearby that I trusted.
XSTNKT
Michigan
The fat end, which you now put at the rear, is there to help protect the side of the truck from rocks/debris when/if you encounter that sort of thing.
The "fat end", is what the OEM's lacky used to type the part numbers into their label printer. That's why the left and right parts stickers are swapped. ;) The assembly plant doesn't a give a hoot what side goes where. They are just following the assembly procedure. And there is enough turnover in the design division there was probably no one was left that knew for sure when the truck actually rolled off the line. They fit both ways. So, it never raised a flag with the factory.
