Irregular F150
its terrain good sir!
After checking it out. The outside of the plastic housing was wet like condensation, soooo hopefully this is all it was :|Probably depends on how humid it was in the cab when you began cooling the air.
Details on your fog light setup?
Thanks! The previous owner of my truck had Rigid cubes and what I assume were Rigid brackets. I ordered two sets of SS3's but had clearance issues similar to you. My brackets look very similar to the ones you ended up with. Unfortunately I didn't try that second slot before returning the lights. I was also considering the BD brackets to go with the SS3's but I guess that won't work either. I just wish DD would add some support for the Gen 1 Raptor. I have reached out previously but they confirmed that they were not planning any products for our trucks.Went with the diode dynamics ss3 sae/dot sport in white and amber combo beam. So i can run them on the roads.
Stage Series 3" SAE/DOT White Sport LED Pod (pair)
<style><!-- .rammobcontainer{ max-width: 400px; margin: auto; text-align: center; } * { box-sizing: border-box; } @media screen and (max-width: 767px) { .ramcontainer{ display: none; } } @media screen and (min-width: 768px) { .rammobcontainer{ display: none; } } --></style> <div...www.diodedynamics.com
Went with baja brackets and didnt work so i got some cheap ones off amazon
Samman Fog Light Mounting Bracket Hidden Front Bumper Cube Light Side Light Replacement Mount Bracket Compatible with Ford F-150 Raptor 2010-2014 https://a.co/32Flg55
and they worked better except the light brackets from DD still had to be set up different. So once I figure this part out i can get a better adjustment to them….
What I would do is get a big old jug of AW32 Hydraulic fluid and run that in the original PS system.Power steering fluid change done! Along with water sweat change too LOL
Was going to wait for the upgrades to arrive but it was dark and burnt smelling so i didnt want to chance it any longer.
When you get the upgrade jack up the front end turn it lock to lock while running, change fluid with more AW32 and repeat until its clear.
Then take out your old system. This will flush out your rack.
If you go with the Lee system the only thing not getting replaced is the rack and it doesn't hold much.
AW32 is about the right viscosity and is usually cheap. Perfect for a flush-out.
I did the same thing... Eventually will get replaced too but it's been great for a couple years now.Got my MBRP turn down installed. Easy job and sounds pretty good for $300. I'm sure it'll rust through in a few years but I'm okay with that for the price.
View attachment 363099View attachment 363100
AW32 is just tractor hydraulic fluid. It is a 10wt mineral oil. The power steering fluid companies like Lee recommend is a 10wt mineral oil. The two have different additives for different applications but someone in the know told me that flushing the system with the AW23 I already had around for other things was a great idea.Hmm ill have to try and find this stuff. Safe to mix?
Im just doing the res and cooler for now, i have more to do (fluids etc) and the pump is good still.
