weird shifting from 3-4 on 2013 screw
Badrap
Haslet, Texas
Hmm. My '11 never showed the gear range at start up unless I hit the shifter but the '13 shows the range on start up.
BearLeeAsian
Dallas Texas
My Raptor with just less than 21,000 miles had a transmission problem that ultimately left me with 3 gears: 3rd, 4th, and 5th. I took it to the dealership where the problem was solved. Below is an account:
Transmission tech wrote:
"Verified check engine light was on. Scanned for codes found code PO722 OSS sensor. Found trans fluid leak inside trans rear bulkhead connector. Performed TSB 13-6-8. R&R molded lead frame connector on megatronics unit. Topped off trans fluid. Cleared codes. Road tested good."
This is a TSB:
TSB 13-6-8 (publication date June 7, 2013)
Issue: Some 2011-2014 Mustang, 2011-2013 F-150, 2012-2013 Expedition and Navigator vehicles equipped with a 6R80 transmission and built on or before 4/8/2013 may exhibit a transmission engagement in 5th gear when starting. The wrench indicator and/or the seat belt minder may be illuminated, the speedometer reads zero and the odometer displays dashes while driving. Symptoms may clear after an ignition key cycle. Diagnostics trouble codes (DTCs) PO720 and PO722 may or may not be stored in the powertrain control module.
Located in the recall section. Sorry can't link it since I'm on my phone.
Mogo
Colorado
Interesting, let us know what you find out from the stealership.
Really? The (+) button works for me, every time I push it the display turns on or off.
I had a chance to test this out this week, we are both correct. The (+) and the (-) both turn the gears display off and on.
:cheers:
