And this is after the dealer replaced your shock absorber?
After the replacement of the shock, suspension check and running the Raptor at 25 mph in 4-HI on the beach over the washboard type surfaces (this is where I initially heard the noise). I do have the leveling kit and know I am not reaching full suspension droop or compression which is the only time I could think of when the suspension or leveling kit would cause a clunk-type noise.
There are three things that I can think of that it could possibly be:
- the leveling kit strut nuts are not torqued enough and there is slop
- that "weight" around the spare tire housing is loose
- the spare tire is not as secure as it seemed when I was yanking on it
So now I will accomplish what I can on my own: drop the spare and search for the "weight." If that does not work then, as I said, off to service I go to have them check the leveling kit they installed.
I really don't mind trying to troubleshoot the issue, it's taking the Raptor out of the garage and driving the whole 8 miles to the beach each time I perform a troubleshooting technique...of course then there is the $10 touchless carwash immediately following the beach excursion.
Keep in mind Dan (and yes I do know it is a sin per forum criteria, but I don't drive often and can drive for about two weeks or more on a tank of gas in my Landcruiser) I only have 3,750 miles on my Raptor since I purchased it in early October.
Hope this answers your question....it also appears I am on a rambling spree tonight.
