I'm going to put bump stop's on the front and rear and under the back seat.
Fox's don't break shock mounts![]()
Always going to be a weak link somewhere. Was happy to see a quick fix for you Greg. Bet you get those mount gussets installed soonBeing one of the people blowing the top of upper shock mounts off.. I am surprised it has not happened more. The metal of the tube is scary thin.. I truly believe this is caused by the aftermarket shocks. Not because the design of the shocks or more resistive force/pressure on the mounts. More like they give you ability to achieve a greater speed off road and in turn that generates a larger force.
With stock shocks at TRR I was lucky to hit 45mph without it being a white knuckle ride. This year with aftermarket shocks, my average speed was close to 40mph.
By going with aftermarket shocks you are moving point of failure from shocks, to the thin mounts..
The lower rear mounts are junk also, mine were tweaked and bent from impacts..
-Greg (aka squatting dog)
