Qtp cut out wired to up fitter switches
BIRDMAN
Birdministrator
Boston
sort of. the tr7 is programmable for many different things for example..... alpine navs require a signal from the foot brake(+) and a pulsed signal and then a latched from the ebrake (-) at the same time in order to use the dvd or nav functions while driving. so you can have a (+) and a (-) being used at the same time or at different times depending on how you program it.
lets say you have a momentary switch (dash switch maybe) you can program the tr7 to send a (+) on the first push of the button and then the next time you push the button it can send a (-) they are also low voltage triggers as well
---------- Post added at 05:51 PM ---------- Previous post was at 05:50 PM ----------
basically the tr7 could replace both of the timed relays
so it's one of those programmable "smart relays"? I have seen and used them in a 120v AC setting but never in a car. I suppose it's the same concept. Those run about $100 for the basic ones right?
The Car Stereo Company
here, on frf
imdubious
Broussard LA
Ill order on and a programmer and play with it next week. I will let you guys know how it works out.
SwampKing
Swampking had these on his f150 Harley maybe he has some info
This I sure did! I stuck with the toggle switch and wiring kit that DMH sent with Their cutouts. I do know that if I was to flip the switch in either polarity longer than 6 seconds or so, might find some burnt motors.
12' Race Red Raptor SCAB (Loaded to the max!)
SCABS are faster!!
08' SeaDoo RXP-X Clockin' 80+ GPS
11raptor6.2
North Dakota
thank you guys for the help. So what's the design/parts I should try this weekend. I kinda understand the drawings but would it be to much to ask to stuplify them? Lol hopefully I can get the correct parts and put together a "how to" with pix for future use for everyone, once again thank you guys for all the help
11raptor6.2
North Dakota
So after getting a PAC tr-7 from local audio shop, and going through the instructions I realized I was kinda lost, so I called PAC audio and they suggested the PAC tr-7 pro.
Reason why is the tr-7 only operates off one input, the Pro can recognize the +12 volt (toggle on) and then be programmed to send a desired timed +12 volt signal out.
Then when the toggle is off, the Pro recognizes the -12 volt and then sends another +12 volts, timed at whatever desired length of time you program it to, to the opposite side of the cut out closing it. So now I'm just waiting for the audio shop to replace the tr-7 with the tr-7 pro.
SwampKing
Great info guys!
Let us know how the pro treats ya
Sent from my iPhone5 using Tapatalk
Aaron
Meme Corps Commandant
WA
Interested to see how the pro turns out too.
