Power steering cooler
J DAMAGE
J DAMAGE
NJ
Hey Nick that should work fine, also can be installed in the same location, still using the fittings, or barbed ends, don't get to crazy with the cooler as for size.
Hole Shot
Raeford, Nc.
I would worry about that being too much for the pump to return through. I wouldn't want to put any more stress on the pump. Just my opinion.
J DAMAGE
J DAMAGE
NJ
There's people running the Howe reservoir, PSC reservoir, both units have screw on filters built into the reservoir, running stock pumps, haven't heard any problems as of yet.
Hole Shot
Raeford, Nc.
I like the idea but I don't think there res. will do much for the issue of the oil sloshing a round and getting air in it.
NickPic83
Rockland County NY
hmmm this is what rock auto shows....
this search was for power steering filter
A-1 CARDONE Part # 20P038F CARDONE Service Plus Power Steering Filter
Our MagnaPure In-Line Filter measures 1.25" X 3" w/ 3/8" Outer Diameter Neck (For 3/8" ID Hose) And Will Only Fit Applications Where Space Allows.; with Plastic Housing
Part Image
$9.54
A-1 CARDONE Part # 200012F {#20FLT3} CARDONE Service Plus Power Steering Filter
Our Magnetic In-Line Filter Measures 2 1/4" X 5" w/12 mm Outer Diameter Neck (Designed For Use With 7/16" or 1/2" ID Hose) And Will Only Fit Applications Where Space Allows.
Part Image
Choose: ($13.04) {6}+ ($14.24) {1}+
+ Sold in packs of {x}; Price reflects cost of each individual item, not the pack
$13.04
A-1 CARDONE Part # 200038F {#20FLT2} CARDONE Service Plus Power Steering Filter One of our most popular parts
with Aluminum Housing; Our MagnaPure In-Line Filter measures 1.25" X 3" w/ 3/8" Outer Diameter Neck (For 3/8" ID Hose) And Will Only Fit Applications Where Space Allows.
Part Image
$14.08
A-1 CARDONE Part # 200058F CARDONE Service Plus Power Steering Filter
Our MagnaPure In-Line Filter measures 1.25" X 3" w/5/8" Outer Diameter Neck (For 5/8" ID Hose) And Will Only Fit Applications Where Space Allows.
these are all basically just magnets with NO filter media. is that because there is filter media some where in the resonator
Hole Shot
Raeford, Nc.
No I think they have some sort of filter element. I have one on back order through summit
