NickPic83
No I think they have some sort of filter element. I have one on back order through summit
what do u have on back order? the oem filter?
just curious does anyone have a pic of the oem filter that is supposedly in the oem resi?
I like the idea but I don't think there res. will do much for the issue of the oil sloshing a round and getting air in it.
Don't know if you can get a good picture with out cutting the side, I can try to take one for you from the fill neck if you want.
---------- Post added at 08:29 PM ---------- Previous post was at 08:26 PM ----------
There shouldn't be any sloshing in there being the filter is dead center of reservoir, working like baffles in a tank truck, slowing fluid movement.
Also need a little fab skills, so it can be mounted.
If you look at the RPG res it has a chamber inside the res to keep all the air out of the fluid.
There's people running the Howe reservoir, PSC reservoir, both units have screw on filters built into the reservoir, running stock pumps, haven't heard any problems as of yet.
