Completed my RPG-PSR and cooler install today, continued from first post
1st-- 2 pic's- the cooler brackets I made them with a 3/4 off set so I can get the cooler placed under the hood latch and closer to the radiator, to keep it out of harms way.
The rest of the pic's are cooler bracket and cooler placement, the install is the same as RPG, and ICON, the only thing I did different was remove the small factory molded hose that comes out of the factory cooler back the the reservoir. In its place I used russell's twist-lok hose that I already had, from past car builds.
My install and plumbing is as follows, RPG reservoir installed, with the fittings that are supplied by RPG, -12AN connected to factory feed to PS-pump, factory line to factory PS-cooler, out of factory PS-cooler to AUX- cooler (using my twist-lock hose and -6AN fittings), AUX-cooler outlet back to RPG PS-Reservoir,(this is where I removed the factory hose). I will be adding the magnefine performance edition inline filter to this set up.
This write up was for the cooler that can be purchased for 27.00 vs 99.00, and the cooler can be purchased with standard hose ends,I chose the route of -6AN fittings, the savings comes to play, if you choose the RPG PS-RESERVOIR, not to big of a savings if you chose the ICON PS-RESERVOIR AND COOLER, but I like to tinker with stuff, so any money saved is money to use on something else.
![RPG Reservoir Mounted-2.jpg RPG Reservoir Mounted-2.jpg](https://www.fordraptorforum.com/data/attachments/38/38495-6b7be1eacc1bcc71c29eb47a65df7972.jpg)
