So next issue I am working on getting corrected is the gap at the top of the rear two fender flares. Inspected few new raptors and all the ones with build dates of March on had tight fits. Several with build dates of Feb like mine had the gaps. Talked to dealer I bought it from and they would have to install and that is 300 miles round trip. He said any dealer should be able to fix as they can order poor fitting body trim without prior approval if within 90 days of original delivery. Dealer today confirmed so if you have similar issue then make sure to get a service ticket open before 90 days.
Met with service manager and a shop lead or foreman today. Apparantly they never had one off before so they pulled diagram and we went through it. Took a bit as I seemed to know how it attached better than they did. But in the end they agreed to order one and if solves the problem then order the other one. Ordered driver's side as it is the worse one. They were very professional so I was perfectly fine with doing one at a time.
If it does not resolve the issue, then I am going to ask they open a case and push it up the ladder as no way a truck this expensive should have a poor fitting part like this.
We will see....here is pic looking down from top of driver side rear fender.
