Need Help! New Light keeps popping the fuse
The Car Stereo Company
here, on frf
check the spades coming out of the switch you are using. make sure they are wired the same as the one with the relay. in this case the middle should go to the lights and the other to constant.... i think..... but check it. also try swapping switches and see what that does
justvettn
justvettn
GTA
Just for curiosity I will test and see if the light works with the first harness with no relay.
---------- Post added at 05:16 PM ---------- Previous post was at 05:11 PM ----------
I was wondering about that as well and when the plug is the same as the plug & play plug it blows the fuse, but I'm not sure if its a good comparison because the switch could be wired backwards as well just like its different in the instructions picture.
here, on frf
it has to be something with the vehicle switch then. double check the wires there. also at the switch you can access it by pulling the center console up. i dont remember if there are bolts, but you can find out easy.
justvettn
justvettn
GTA
I am willing to try just about anything, but that same switch and same wiring lights up my D2 light when I plug it in to that very same plug that wont light up my 4" light.
Why that switch and wiring works on other lights but not the 4" may never be solved.
here, on frf
take the relay off and connect 86 to ground and connect 85 to your trucks switch listen and try to hear the relay click when you flip the switch. do not connect anything else to it
---------- Post added at 03:02 PM ---------- Previous post was at 03:00 PM ----------
going to see about a 13 if you havent been able to fix it yet then when i get back we can discuss it more
justvettn
justvettn
GTA
Just spoke to Rigid tech who had the chance to ask the Rigid owners what could be the problem and the only thing they can think of is that for some reason the light is drawing to much power and blowing the fuse. They suggested sending them the light for examination. I just hate shipping the light back with out knowing if that's the actual problem.
Hockster
My 45ft Bluewater Party
Winchester, Va
Do you have another light you can use with the same draw? that would take the wiring out of the question
justvettn
justvettn
GTA
Yes I tried a spare D2 light that draws a little more and it works fine, so I think I can eliminate the wiring. Rigid E-series 4" draws 1.18 amps and D2 draws 1.8 amps.
Just for the heck of it I will hook up two D2's and see what happens.
---------- Post added at 07:50 PM ---------- Previous post was at 07:13 PM ----------
I have come to the conclusion that something is wrong with the light and will ship it back to Rigid tomorrow for a tear-down.
