Need Help! New Light keeps popping the fuse
The Car Stereo Company
here, on frf
what kind of test light? one that goes into you cigar lighter or one that goes to ground?
---------- Post added at 04:18 PM ---------- Previous post was at 04:15 PM ----------
i have a problem car right now, if you dont find a fix, when im done i will see what i can do
justvettn
justvettn
GTA
First picture is the ground, second is connection to the under hood wire, third I pulled the wires up to check if they may be shorting out at the spliced connection. fourth is connection under the dash small brown wire to purple. last picture is just the plug connection.
---------- Post added at 07:24 PM ---------- Previous post was at 07:18 PM ----------
do u have a continuity tester?
I have a multi meter, I will see if it has that. Not sure how to use it though for continuity.
---------- Post added at 07:25 PM ---------- Previous post was at 07:24 PM ----------
Its the one with the ground.
NickPic83
Rockland County NY
if u can figure out how to use it try this. with the switch OFF disconnect the plug goin to the light. now on the FEED side put one tester lead on the power(red) wire and the other on ur ground. if u read continuity then u have a dmamged power wire and should replace it.
justvettn
justvettn
GTA
Strange that the up-fitter switch lights up even though the fuse is blown?
justvettn
justvettn
GTA
Thanks, I will give that a try.
justvettn
justvettn
GTA
OK, so the Multi-meter shows that the wiring is good according to the continuity tests.
The problem is that Rigid has the wiring backwards in the light plug socket so when plugged in it shorts out.
NickPic83
Rockland County NY
o ok. yeah that was my next thought turn on the switch while the light is unplugged. glad u got it figured out
