Installed 37's on Gen3 35 Raptor - no issues.
MORaptor1
SW Missouri
Another 37s on a 35 truck with zero issues. Couldn’t be happier with the way it drives. Maybe the lighter FP Forged wheels but I swear it just seems lighter on its feet. I am still on stock suspension and have had zero rubbing with some mild off road driving so far. Did go with a 17x9 +12 offset so that helped a lot. Spare fits no problem. The ideal of moving the winch location back to pull the tire up and back has me thinking, so the next time I have the truck on the lift will check into how tough that would be. Only thing left to make it perfect is fix the speedometer. Thinking about going the Cobb route. Just hate to send my cpu off but it appears they have great turn around. View attachment 422000View attachment 422001
Could you post a front or back pic? Id like to see how much or little that setup sticks out.
Bozz
Royal Smart A$$
Nashville, TN
I know me either. It happened the day after I installed them so I had to take a PIC. Dumb to post I guess but thought only guys here would understand.
Dandridge near Knoxville.
Been to Dandridge. Friend of mine has a cabin there. Nice area.
MORaptor1
SW Missouri
So sticking to 37” ko2 tires……will a 0 offset clear? +6 the limit? +12? I will never jump this truck or beat on it.
So-Cal-Al-52
I Love Fossil Fuel
San Diego
I have a 37 so I am guessing a little here. But 37 KO2's should fit with any of those offsets. The Gen3's have a lot of room in the wheel wells. Are you leveled via collar or springs? If so even better for clearance and it will be no issue especially if you don't jump or fully compress up into the fenders. +6 and +12 will clear for sure, 00 offset brings the fender flares into play during compression. Someone here will have the exact set up you are asking about.
ktrent
tn
I would say the wheel itself is even with the fender flare. The +12 in a 9" wheel would be very close to a +6 in a 8.5" wheel and the 9" wide pulls the tire in a little more. I was dead set on 8.5 00 offsets but after getting these I am super happy. Drives as good as stock also. Zero rubbing...
MORaptor1
SW Missouri
View attachment 422826View attachment 422827
Thanks for the info. I think I’m going to do 0’s and stick with 35’s…..
