Installed 37's on Gen3 35 Raptor - no issues.
4x4ready
4x4ready
USA
Im going to measure mine from a couple different reference points and post that....hopefully somebody with a 37pp raptor will have a chance to do the same. Something is different i suspect.
There were a few videos we found back when it was released confirming there was a difference but yes would be awesome to get the specifics.
munch520
Midwest
Shit I've had that thing down a few times to work on springs, rear bed bolts, diff cover, etc. It's been used all the time
TBH I have no idea, I think it's bolted in place, never thought to check since the "37 inch" KO2s are basically same weight as factory 35s.
MORaptor1
SW Missouri
That would be good. If it’s bolted, it can be unbolted and moved.
taquitos
Seattle
It is for sure bolted. The bracket it bolts to constrains it fairly well and would need modification beyond just slotting the holes most likely.
ktrent
tn
Another 37s on a 35 truck with zero issues. Couldn’t be happier with the way it drives. Maybe the lighter FP Forged wheels but I swear it just seems lighter on its feet. I am still on stock suspension and have had zero rubbing with some mild off road driving so far. Did go with a 17x9 +12 offset so that helped a lot. Spare fits no problem. The ideal of moving the winch location back to pull the tire up and back has me thinking, so the next time I have the truck on the lift will check into how tough that would be. Only thing left to make it perfect is fix the speedometer. Thinking about going the Cobb route. Just hate to send my cpu off but it appears they have great turn around. IMG_2522.jpegIMG_2549.jpeg
Bozz
Royal Smart A$$
Nashville, TN
Another 37s on a 35 truck with zero issues. Couldn’t be happier with the way it drives. Maybe the lighter FP Forged wheels but I swear it just seems lighter on its feet. I am still on stock suspension and have had zero rubbing with some mild off road driving so far. Did go with a 17x9 +12 offset so that helped a lot. Spare fits no problem. The ideal of moving the winch location back to pull the tire up and back has me thinking, so the next time I have the truck on the lift will check into how tough that would be. Only thing left to make it perfect is fix the speedometer. Thinking about going the Cobb route. Just hate to send my cpu off but it appears they have great turn around. View attachment 422000View attachment 422001
Never seen tpms indicate the same pressure on all four tires before. EVER.
Where you at in TN?
