Installed 37's on Gen3 35 Raptor - no issues.
Ckhris
would installing the Ford 37 Perf front and rear springs and shocks on the 35 suspension… would that work to keep it semi stock vs the after market springs when adding 37s?
MORaptor1
SW Missouri
Probably very expensive and dont know it if would be a direct swap.
BIGW0RM
Highest Access Member
Pirate
Let me ask this... Could I get 37" Toyo or Nitto on all 4 corners and use a KO2 37 as the spare? Would the size difference between true 37's and one KO2 37 spare grenade my transmission if I had to use it to get out of a flat?
BIGW0RM
Pirate
^^^Looks good. Is that a method 703? Are the blue or black? All you need now are some husky fender liners to clean up the white showing in the rear fender well.
failed_1
NM
Would a true 37, specifically Ridge Grapplers, rub if I stuck with a +12 or so wheel with no lift? Would the stock 37PP wheels rub with a true 37 tire and no lift?
winning
The OC
Yep a 703 in the new Bahia blue color (matched my blue Recaros)- and yes, fender liners are on order, also adding Camburg uppers arms to hide the ugly ford ones while adding to uniball beef
BIGW0RM
Pirate
Nice! Ah, I need to do that too! I leveled mine and now mine really show. Thanks for the suggestion! lol.
