I have used on and off a Matco, Snap On and Ingesoll Rand air Impact wrench. I finally invested in a Ingersoll Rand cordless impact wrench. I was a bit doubtful at first it could hold up to any air wrench but man this thing is simply outstanding. If you don't want to invest in a comprssor a bunch of fittings, hoses etc. look at the Ingersoll Rand W7150 cordless impact wrench. It matches.....yes...... I said matches IR's top Air Impact wrench in power and torque. I could not believe the power this thing has. Battery holds a charge, it seems forever. Charges back in less than thirty minutes. This is one bad ass impact wrench and no compressor or hose to fool with. If you do much work on your vehicle, you know you will eventually need an impact wrench. I did not want to go through all the issues with air but I was a little concerned about any cordless impact wrench. I rolled the dice and boy was I surprised and pleased with what I got. If your in the market be sure to check out this impact wrench.
and NO I do not work for IR........just passing along what I hope is some helpful information.
