random codes and the wrench
bolands
2019 raptor experiencing Park brake limited function, blind spot fault, cross traffic fault and hill descent control fault. somtimes wrench will also show up. Forscan shows a bunch of "U" communication errors. Please help! i have listed the forscan DCTs.
===TCM DTC None===
Successful DTC reading, no error codes found
Module: Transmission Control Module
===END TCM DTC None===
===PCM DTC P05B0:00-2F===
Code: P05B0 - Active Grille Air Shutter 'B' Position Sensor Minimum/Maximum Stop Performance
Status (-2F):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===END PCM DTC P05B0:00-2F===
===PCM DTC U0131:00-2E===
Code: U0131 - Lost Communication With Power Steering Control Module 'A'
Status (-2E):
===END PCM DTC U0131:00-2E===
===PCM DTC U0137:00-2E===
Code: U0137 - Lost Communication With Trailer Brake Control Module
Status (-2E):
Freeze Frame #1:
Freeze Frame #2:
-MODULE_VOLTAGE: 1.5 V - Control Module Voltage
-LONGFT2: 90.63 % - Long term fuel trim 2
===END PCM DTC U0137:00-2E===
===PCM DTC U0199:00-2E===
Code: U0199 - Lost Communication With Door Control Module A
Status (-2E):
Freeze Frame #1:
Freeze Frame #2:
===END PCM DTC U0199:00-2E===
===PCM DTC U0200:00-2E===
Code: U0200 - Lost Communication With Door Control Module B
Status (-2E):
Freeze Frame #1:
Freeze Frame #2:
===END PCM DTC U0200:00-2E===
===PCM DTC U023A:00-2E===
Code: U023A - Lost Communication With Image Processing Module A
Status (-2E):
===END PCM DTC U023A:00-2E===
===PCM DTC U0256:00-2E===
Code: U0256 - Lost Communication With Front Controls Interface Module 'A'
Status (-2E):
===END PCM DTC U0256:00-2E===
===PCM DTC U0298:00-2E===
Code: U0298 - Lost Communication With DC/DC Converter Control Module 'A'
Status (-2E):
Freeze Frame #1:
Freeze Frame #2:
===END PCM DTC U0298:00-2E===
===PCM DTC U1012:00-AF===
Code: U1012 - Invalid Internal Control Module Monitoring Data Received from Anti-Lock Brake System (ABS) Control Module
Status (-AF):
- Malfunction Indicator Lamp is On for this DTC
Freeze Frame #1:
Freeze Frame #2:
===END PCM DTC U1012:00-AF===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC None===
Module: Accessory Protocol Interface Module
===END APIM DTC None===
===DCDC DTC None===
Module: DC to DC Converter Control Module
===END DCDC DTC None===
===PAM DTC U0100:00-2A===
Code: U0100 - Lost Communication With ECM/PCM A
Status (-2A):
Module: Parking Aid Module
===END PAM DTC U0100:00-2A===
===PAM DTC U0101:00-2A===
Code: U0101 - Lost Communication with TCM
Status (-2A):
===END PAM DTC U0101:00-2A===
===PAM DTC U0121:00-28===
Code: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module 'A'
Status (-28):
- Previously Set DTC - Not Present at Time of Request
===END PAM DTC U0121:00-28===
===BdyCM DTC None===
Module: Body Control Module
===END BdyCM DTC None===
===BECMB DTC None===
Module: Battery Energy Control Module B
===END BECMB DTC None===
===SODR DTC None===
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC None===
===SODL DTC None===
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC None===
===IPMB DTC None===
Module: Image Processing Module B
===END IPMB DTC None===
===FCIM DTC None===
Module: Front Controls Interface Module
===END FCIM DTC None===
===ATCM DTC None===
Module: All Terrain Control Module
===END ATCM DTC None===
===TRM DTC None===
Module: Trailer Module
===END TRM DTC None===
===DSP DTC None===
Module: (Audio) Digital Signal Processing Module
===END DSP DTC None===
===SCME DTC None===
Module: Front Seat Climate Control Module
===END SCME DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===C-CM DTC None===
Module: Cruise-Control Module
===END C-CM DTC None===
===TCCM DTC None===
Module: Transfer Case Control Module
===END TCCM DTC None===
===ABS DTC U0100:00-2E===
Status (-2E):
Module: Antilock braking system
===END ABS DTC U0100:00-2E===
===ABS DTC U0146:00-2E===
Code: U0146 - Lost Communication With Serial Data Gateway 'A'
Status (-2E):
===END ABS DTC U0146:00-2E===
===ABS DTC U0401:00-AF===
Code: U0401 - Invalid Data Received from ECM/PCM A
Status (-AF):
===END ABS DTC U0401:00-AF===
===TrlrBM DTC None===
Module: Trailer Brake Control Module
===END TrlrBM DTC None===
===TCU DTC None===
Module: Telematic Control Unit Module
===END TCU DTC None===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===DSM DTC None===
Module: Driver's Seat Module
===END DSM DTC None===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC None===
Module: Drivers Door Module
===END DDM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PSCM DTC U0100:00-0A===
Status (-0A):
Module: Power Steering Control Module
Freeze Frame #1:
-STEER_FEEL: Comfort - Steering Personalization Status
-STRWHL_POS_CAL: Yes - Steering Wheel Position Sensor Calibration
-SW_RAW: -161.10 ° - Steering Wheel Angle - Raw
-SW_ANGLE: -113.70 ° - Steering Wheel Angle
-SSHFT_TQ_S2: 3.1 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: -39.30 ° - Steering Wheel Angle Alignment Offset
-TOTAL_DISTANCE: 203424 km - Total Distance
-EVENT_TIME: 169493296 s (Sun Aug 18 10:41:31 2024) - Event time
-ECU_POWER_SUPPLY: 14.0 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 32 °C - ECU Internal Temperature
-EPAS_MOTOR_CUR: 75.40 A - EPAS Motor Current
-VSS: 0.0 km/h - Vehicle Speed
===END PSCM DTC U0100:00-0A===
===ACM DTC U3000:88-0A===
Code: U3000 - Control Module
Additional Fault Symptom :)88):
- Bus Off
Status (-0A):
Module: Audio Control Module
===END ACM DTC U3000:88-0A===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===VDM DTC None===
Module: Vehicle Dynamics Module
===END VDM DTC None===
===IPC DTC U0415:00-0A===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module 'A'
Status (-0A):
Module: Instrument Panel Control Module
===END IPC DTC U0415:00-0A===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===HSWM DTC None===
Module: Heated Steering Wheel Module
===END HSWM DTC None===
===IPMA DTC U0100:00-2E===
Status (-2E):
Module: Image Processing Module A
Freeze Frame #1:
-EVENT_TIME: 169493297 s (Sun Aug 18 10:41:32 2024) - Event time
-MODULE_VOLTAGE: 14.3 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 24 °C - Outside temperature
-VEHICLE_SPEED: 2 km/h - Vehicle Speed
-ECU_POWER_SUPPLY: 14.3 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 62 °C - ECU Internal Temperature
===END IPMA DTC U0100:00-2E===
===IPMA DTC U0418:86-2E===
Code: U0418 - Invalid Data Received from Brake System Control Module 'A'
Additional Fault Symptom :)86):
- Signal Invalid
Status (-2E):
Freeze Frame #1:
-MODULE_VOLTAGE: 14.5 V - Control Module Voltage
-ECU_POWER_SUPPLY: 13.9 V - ECU Power Supply Voltage
===END IPMA DTC U0418:86-2E===
aFallenTree
Colorado
Quick diagnosis from me is you lost connection or wires got cut/chewed to those modules. Have you looked at the truck for any obvious signs of issues?
B
bolands
Did not see any chewed wires. Had the battery checked today. All good there. Checked spark plugs and cleaned the throttle body today. No codes after all that.
zacharyguyjordan
Mustache Monster
Bennett Co
Did you use a spray on your throttlebody? Or just wipe it down.
