spd downpipes and k&n inlet pipes
FmaxTurboSi
FmaxTurboSi
So Cal
Hate to tell you but those marks are from mice or other rodents. Better park in a new spot and take some action against them or you going to have electrical problems….
Na it’s cats. There was tons of cat hair on top of the cover also. Even my own cat sleeps up there when she accidentally gets locked outside for the night.
leinad1904
Around St. Louis
Alright guys, just made a 500 mile trip with the new downpipes and inlet tubes. If anybody is on the fence about doing this, just do it. I was hesitant for a while, but I wish I would've done it sooner. I hate aftermarket exhausts and deletes on our ecoboost trucks. To me, they're annoyingly loud and drone way to much. These are sort of a "sweet spot" for me.
The downpipes sound slightly more throaty and just a tad louder. The sound clips do not do these any justice. The new normal exhaust mode is like the old sport, the new sport is like old baja, and the new baja is crazy. I punched it under a tunnel today in baja and it screamed. Cruising on the highway in normal mode is just barely louder. My wife didn't even notice it with the radio on and all the road noise. Under regular acceleration you can tell it's more throaty. And wot it sounds amazing. For me, these really are awesome, bcuz again, I hate drone and annoying loud exhausts when driving normal. Cold starts and idle after warming up are slightly louder than normal as well.
With the windows down and driving around the neighborhood, stop sign to stop sign, the turbo noise is also significantly louder. I'm not sure if it's just the downpipes, or the combination of downpipes and inlet tubes, but it's definitely noticeable.
The quality, fit, and finish of the SPD downpipes 10/10. I've installed various exhaust systems, downpipes, and even complete turbo kits on cars and trucks in the past, and I have to say the fit of these downpipes exceeds anything I've ever done.
When removing the oem exhaust, I'll suggest having 2 different size crows foot wrench's. I believe it was a 13mm for the exhausts sleeve clamp at the rear end of the downpipes. The bolts are on the top side of the clamp and damn near inaccessible. I didn't have enough leverage using a standard wrench and there's not enough room to get anything larger like a breaker bar in their. The other is a 22mm crows foot wrench to remove the o2 sensors from the oem downpipes. If you have a 22mm wrench it'll probably work if you can add extra leverage. But the 22mm crows foot with a breaker bar worked perfectly. The old crescent wrench with a hammer method was not cutting it LOL.
The k&n inlet tubes was an awkward installation. The passenger side is a tight fit and reaching all the way down in the engine compartment was kind of pita. I have my LVJ relay panel mounted on my battery tray and it was my way for the install. So I went ahead and removed the relay panel and the battery to have more room to work. The instructions say to trim 3/8" off the passenger tube, near the turbo end, "if you have a 2023 model or later." I have a 2022, and I couldn't get it into position without trimming. So if you also have a 2022 and can't get it, don't feel bad, you aren't the only one. These aren't boost tubes where they're under a lot of pressure, so it's not going to matter. As long as you're able to get the tube inside the rubber adapter and tightened down with the hose clamp, you're good to go.
Nice, I've been on the fence too. I put the AWE 2FG on my gen2 and it was so damn loud, definitely don't want that again. I definitely expected loud but holy F!
I keep listening to the turbo spool on @GooseTuned 's video with @WTX 's truck and I definitely want to pull the trigger. I just need to find e85 near me, nobody seems to sell it.
FmaxTurboSi
FmaxTurboSi
So Cal
I dont think field mice have cat hair and meow. But maybe there's a new breed i need to be worried about?
WTX
The Permian Basin
The truck still runs very strong on 93.
I never knew E85 was available at several places around here until I actually had to look for it.
I scan for yellow handles as I drive past stations. I can make it all the way across TX on E85 now.
Google map is the best place to search.
Sparda1123
Orlando, FL
You beat me to a write up so I'll add supplemental pics. I did lower temp thermostat, Inlets, hot & cold piping, intercooler and downpipes at the same time. While you don't need to, if you remove the passenger side wheel well liner you get a ton of access to the passenger turbo. 20240615_160403.jpg20240615_160735.jpg20240615_195430.jpg20240615_202558.jpg20240615_202613.jpg
leinad1904
Around St. Louis
Google Maps led me wrong a few times here advertising "E85 sold here" but when I go check it out they only have unleaded and diesel. According to the DoE website there are two but both are 23 and 24 minutes away. I may just go with 93 and race Prius's.
@FmaxTurboSi did you need to replace any bolts or anything else during the install? I am going to install mine Thursday or Friday and want to make sure I am prepared.
FmaxTurboSi
FmaxTurboSi
So Cal
I did not need to replace anything no. Everything was included. Just make sure you have something to remove those o2 sensors off the oem pipes and the nuts on the rear exhaust clamp.
WTX
The Permian Basin
I know what you’re saying. I’ve found if you scroll through the section with price per gallon it will tell you if they really have E85. Most stations listed say they do when they don’t. Obviously if the price isn’t listed they do not have it.
