2019 "Live" suspension mods
zombiekiller
OG BooBooRunner
New Orleans
Because geiser springs are progressive, they will be softer during daily driving duties. As they compress they have more effective spring rate.
The eibachs are a linear spring, which will be stiffer.
Stock, the trucks nose dive quite a bit, a collar lift of about 1.5" made the factory spring perfect for me.
I swapped to fox factory 3.0s (which are very much worth it), and have since swapped the the fox coilovers out for Kings .(the fox 3.0s don't work with my midtravel kit).
If you have the coin, go right to 3.0 remote resis. If you're going to beat on the truck, I'd double down on this recommendation.
If you plan to add UCAs, disconnect the front sway, go geisers, and beat on the truck, do yourself a favor and add limit straps so you don't destroy your front shocks by pulling the shaft out of the shock body at full droop.
WillieFlo
Houston
You guys are great. I guess I had it backwards.
This forum has been very helpful already! Thanks
Kahuna
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Don't rush into it is my suggestion. Take delivery. Drive the truck for a few weeks. See how it handles. Then (if they end up being compatible) get some Geiser front springs and Deaver/Atlas/Icon rear springs if you want a little extra height. You will experience what the upgrade felt like and will learn something for the next truck you buy.
Kahuna
Kahuna
Question for the gurus out there...
The new shocks have a cup in the body which provides extra damping for the last 25% of the stroke. Did the old shocks have that? Will that negate the need for hydraulic bumps all together of just help stop bottoming?
Loufish
Burbank CA
Yes the "old" 2017-2018 frt and rear shocks had internal valving parts to create a bump zone to reduce harsh bottoming...
zombiekiller
OG BooBooRunner
New Orleans
Ever hear the old adage " 2 is one, one is none"?
If you put all of your trust in a singular failure point ( the shock) , you have zero protection if something happens to the shock. The whole point of a bump stop is to protect the vehicle and the occupants if you push the truck beyond what the shock can do, even temporarily.
Not to mention, the rear shocks are offset and angled. The required sheer strength of the components of the shock and the mounting brackets so that they MIGHT hold up to a full bump, 1/4" from metal to metal scenario would put ford's metallurgy team outspending nasa.
just for clarity- this is RE: the rear suspension.
Sharkus29
Kickin it in Canada!
My buddy who just got back from SEMA said that he talked to Fox and they said because of the height sensors in the new Live Valve shocks that they are not upgradable and we won't be able to use the gieser springs and Deavers :S So take it with a grain of salt obviously, but thats what the reps told him while he was there
Kahuna
Kahuna
Interesting. Sounds like we will have to wait till the big brains get their hands on a set.
FordPerf Addict
What about Deavers that don’t change the ride height? Shouldn’t be an issue no? Maybe I’m not sure how they are actually set up
WillieFlo
Houston
Sharkus29,
I was afraid of that being the case. I’m sure someone will eventually engineer something that will allow you to modify ride height.
