Tools and things
Pancake1291
Utah
HI,
I am pretty new to off roading a truck. I want to start taking the truck out a little further into the desert and I will probably be alone sometimes. I know its not ideal but it is what it is. Is there a tool bag or kit that people like for the raptor to keep on hand to repair possible failures? Are there spare parts people carry other than tires? When I was in the market one thing I noticed on a lot of raptors were car fax/service records shown serpentine belts, so I have a spare of those and a spare 4wd actuator motor. I have a fuse 27 relocation kit ready to install on the next good weather day I have off work. Freezing temps and 12 year old plastic is a rough combo. My truck is all stock 150k miles. Has anyone made a list of recommended tools? I appreciate any advice and opinions.
Bigt3141
Tucson
I would carry a spare fuel pump module, mine went out and I was about 150 miles to the nearest place that could fix it, had I carried one I could have fixed it on the spot and drove home instead of an expensive tow. I also carry a small Bluetooth computer scanner to aid in troubleshooting. Not sure what else to carry though as I'm doing the same thing as you. And I think I'll add a spare serpentine belt to my kit now.
P
Pancake1291
Utah
Something like this is what your referring to? https://www.livernoismotorsports.co...chj3b26r44ZH1EVE7mHQ697vKNKaWmUuBOZpHSlVsXlWR
or this
https://www.amazon.com/dp/B00M37WF9M/?tag=fordraptorforum-20
Anytime something has to be replaced I'm just upgrading in plans to keep the truck forever. Unless its a sensor.
Ricoman
WASHINGTON STATE
Jhollowell
Everett, wa
I carry all the wrenches and sockets needed to tighten all the suspension and steering bolts. I also have a spare serpentine belt and tensioner in the truck as well. I'd also throw a quart of PS fluid and brake fluid in if you're running around in the dunes.
Bigt3141
Tucson
or this
I believe the second one, it's mounted to the frame in the rear near the gas tank. If anything inspect it now because it's in a bad location that's exposed to the elements.
P
Pancake1291
Utah
Or this
What am I looking for when I inspect it? Or is there a way to test it? It currently works obviously
Bigt3141
Tucson
Or this
I've read several posts on F150 forums about them being cracked and corroded due to its location. I don't know what was wrong with mine as the shop that it was towed to fixed it under my warranty.
