What did you do to your Raptor today? (Gen2)
nikhsub1
Los Angeles
This is exactly what I am about to do. How was the install? Any issues?
The hardest part on my truck were the 3 shock tower bolts. The passenger side was a serious PITA as there was barely any room. For the lower shock bolt use a breaker bar with a jack handle to get even more leverage, you don’t need to hold the bolt to break it loose. Lastly, be very mindful of the abs sensor wire, it runs back near where the UCA bolts are - if you aren’t careful you can get it caught behind the UCA bolt and sever the wire. Ask me how I know [emoji849]
Rednose
Dubai
I had to remove my 20 inch onx because I wanted more airflow to the IC so I replaced it with 2 lp6’s and the KC mount was the perfect solution instead of welding on a new bar for the mounts.IMG_3505.jpgIMG_3506.jpg
Speeddeacon
NC
Does that improve the airflow to the IC? Someone asked me about that very thing when I mounted the 10” bar in my lower grill. It is less surface area than a license plate that Ford mounts there so not concerned. Those LPs aren’t exactly small either, albeit smaller than the LP9s. Obviously there are a lot of trucks with even multiple pairs of them mounted but you never know what issues they may have.
Rednose
Dubai
I haven't driven the truck yet it was only a 10 mile trip to home, But I will be trying it this week and give some feedback. I was running a 20 inch onx bar which covered the whole surface area of the inter cooler vent plus having an overheat problem so I am trying to sort it out the best way I can. My Full Race radiator is shipped and I ll be receiving it soon, lets see if that sorts my problem ,if not I will be going with the CVF IC and the game never ends!!!!
I attached some before and after picture to see the difference.
