CoronaRaptor
That’s the cleanest part under your hood now!
thats the truth! Give it a weekend and it will matchThat’s the cleanest part under your hood now!![]()
Where are you putting the amp? I am eventually putting a custom made 6.5" sub box in the Sony sub location and I already have an underseat storage box covering the rest of that area. Hoping for room behind the seat or maybe under the center consoleJL Audio HD900/5 (4x100+500x1) to put in when I have time and figure out a sub solution.
I haven’t finalized that yet. I’m a bit concerned about the amp overheating so I’m planning on making it fit under the rear seat somewhere. If I have to relocate the jack then so be it but I should be able to make it all fit.Where are you putting the amp? I am eventually putting a custom made 6.5" sub box in the Sony sub location and I already have an underseat storage box covering the rest of that area. Hoping for room behind the seat or maybe under the center console
Paid the nice people at the stereo store $200 to do the extensive dash hacking required on a 2011 with nav.I totally jacked up a stereo install. So I’ll be taking it to the pros tomorrow.
I have 2 audiocontrol 800w amps behind my seat and run them pretty hard and I've never had them fault for overheating, I also live in the desert if that helps you make your decision. Also audiocontrol amps run pretty efficiently and don't output a ton of heat so that could affect your install as well.I haven’t finalized that yet. I’m a bit concerned about the amp overheating so I’m planning on making it fit under the rear seat somewhere. If I have to relocate the jack then so be it but I should be able to make it all fit.
This weekend I am going to pull the factory sub unit and see what I’m dealing with. Tentative plans are to reuse the box with an upgraded 8”-er. I may add a few thin layers of fiberglass to the inside to stiffen it up if it seems flimsy and the cubic volume allows it. I know I may have to trim and tweak it a bit but I’m fine with that.
I’m not looking for crazy, thumping bass at ear bleeding volume so I think it should be doable with my plan.
I checked and have plenty of room between the sub and jack for the amp. Now all I need is time to put it all together.I have 2 audiocontrol 800w amps behind my seat and run them pretty hard and I've never had them fault for overheating, I also live in the desert if that helps you make your decision. Also audiocontrol amps run pretty efficiently and don't output a ton of heat so that could affect your install as well.
