Waiting to hear back from Ford SVT on springs through my dealer.
Ok, well this is turning into more than I figured on a couple different levels. First, I know the Raptor isn't a tow vehicle (for my needs anyhow) but it is what a F150 should be in my mind. Towing is its only problem I have. A bit more fuel mileage would be nice, but towing/hitch weight is my issue.
My previous pickup (s) I installed Air Ride bags on. Pulled my 24' enclosed car hauler (est 10,000lbs) OK. Power was minimal, fuel mileage was 8.5mpg, but it worked for no more than I pull.
I never installed an equilizer hitch on that trailer or the 18' flatbed I use as well. I picked up a Anderson #3350 No Sway Weight Distribution Hitch yesterday. $425 out the door, simple as I have seen, and it does work. Still doesn't cure my issue with the Raptor, but wish I would have had this on my other pickups. Would have been awesome especially with air bags.
The Anderson I bought is rated at 14,000lbs, 1,400lbs tongue weight.
These are my wheel lip results:
Unloaded trailer (no car) On Concrete
LR 42 3/4
RR 43 3/8
LF 40 3/8
RF 40 1/2
Empty Trailer with adjusted Anderson Hitch
LR 40 7/8
RR 40 3/8
LF 41
RF 41 1/4
Trailer with 900lb Polaris 4 wheeler up near cabinets.
LR 40 3/8 (.5" to bump stop)
RR 39 3/4 (.250 to bump stop)
LF 41 1/4
RF 41 3/8
I really think the Anderson hitch is good stuff, Anti Sway built in, Simple, quick to hook up, etc.
Obviously I am going to have to beef the rear Raptor springs up a touch more before loading a car in this thing.
I looked to Super Spring:
They make two applications.
SSA5 with MTKT Kit 950lbs addition is what they told me.
SA28 with no mount kit is 1500lbs.
I think I am going to look at the SA28 as it doesn't require the mount kit. I may be wrong, but if I replace the two shackle bolts with hardened pins and clips, I could remove the complete spring set up in a matter of minutes and gain my daily driving ride back.
The SSA5 would likely get me by with the Anderson hitch to get the rear of the truck higher off the stops, but the SA28 may be quick detach.
Thoughts or experience with the Super Springs?
I'll post pics shortly.
---------- Post added at 08:19 PM ---------- Previous post was at 07:32 PM ----------
With 4wheeler at front of trailer:
