Netix
Banned
I have a super 10 and have no drone, check your ears
If it's loud... it's going to drone somewhere. It's just resonance.
The major factor controlling how much it will bother you is where you put the muffler and the exhaust's exit point.
Check out the Stainless Works Catback for best sound, performance and value. We exclusively use 304L stainless steel which is american sourced, very high quality, no thin recycled pop can material here!
I've been considering the Borla setup but I'm trying to find some installed near me so I can decide between the Touring & Stinger systems. I've watched clips on YouTube but no one puts which of the systems that they are running. And besides that, hearing it on YouTube doesn't really capture the actual sound...
The mufflers I use are the Borla S Type.
If you have a good set of speakers or use head phones it will give you a good idea of how it will sound.
Just installed full SW exhaust. The system is awesome, and sounds great. However, bad drone at higher gears and low RPMs. I am hoping Mike At 5star can adjust the tune to keep engine at higher RPM. Any others having this? If so what did you do to fix? I see SW has a resonating tip, has anyone used?
Thanks.
