Sway bar removal pros and cons
Dkyacht
Fort Lauderdale
Thanks for that! I guess sleepy typing is almost as bad as drunk typing! So on with the subject, I saw the kit referenced for quick removal and love it. I am more interested to find out the good and bad of doing this mod?
Dave
vanilla_gorilla
NorCal (Sacramento)
Nope you're screwed now! Lol.
FWIW I am pulling mine off again this week. It comes off when I am home and goes on when I leave since the wife hates driving with it off.
My wife hates driving without the sway bar too. But she will once in awhile.
But I removed mine a couple months ago and drive mainly on-road, but I love the "rock the boat" feel the truck has now. And I cannot report of any extra wear and tear, but I know the off-road handling is great, the steering wheel doesn't fight you and the ride is smoother.
Because this "mod" is SUPER easy, you really could just take it off for a day or two and see how you like the feel of the truck without it. If you decide you don't like it, it just takes 10 minutes to install it. Two nuts on the passenger frame rail and three nuts on the driver frame rail and then just undo the bolt on each lower control arm. Tip on removing the nut/bolts on the LCR, they are safety nuts (That's what she said), so they will just spin, you need to put a wrench to the nut and bolt to remove the connecting rods.
Netix
Banned
Ontario, Canada
took it off months ago. never felt a difference on the street. until i started hitting speed bumps doing 80 and curbs. off road... everything was better. Im on top perch and for 10,000 km no sway, ill be staying that way
Boss327
Nor Cal
I've had mine off for a while now and I have no cons to report.
gbrown27
Auburn, Al
Sway Bar
What are the pros and cons of disconnecting the sway bar?
I don't see high speed since I'm in Georgia so I see more trails with mud and rocks
BOJANGLES
<span style="color: red;"><b>Administrator</b></sp
Chihuahuan Desert (EPTX)
The front suspension operates more independently (better off-road) with the swaybar removed. You will feel a bit more body roll on the street, but it is well worth it if you're an off-roader
gbrown27
Auburn, Al
How about perch settings? I'm greeting a stealth fighter put on tomorrow and need to decide top or middle
Aaron
Meme Corps Commandant
WA
There's not a lot of cons really other than a bit more body roll like Bo mentioned.
Off-road there's a huge difference with it disconnected. It makes the truck a lot more stable through the choppy stuff and lets your wheels work independently of each other.
---------- Post added at 08:29 PM ---------- Previous post was at 08:28 PM ----------
On the perch I went with mid and I like it a lot, I've been mulling over top though. Mid feels like the setting the truck should have come stock with.
gbrown27
Auburn, Al
I really think that the bumper could help pull the front end down a bit so I want to go top but from what I've seen on here, middle Is perfect.
The problem is that the SCrews look somewhat unproportional and the middle doesn't look like a big difference
Aaron
WA
The bumper will pull the front end down a bit, My mid isn't as high with my ADD bumper as others with the stock bumper. The stock bumper is pretty flimsy though.
That's exactly why I'd been considering top.
