SVC WHIPPLE Supercharger Kit
PropDr
Eugene, Oregon
PropDr, you've been around on the forums a while,
you haven't read the 100's of post on Oil Pump Gears and pushing really big power? 550+ rwhp
Last count I have is 13-15 blown oil pump gears. Not every one is on the forums. Most are in Dubai beating that crap out of them in the sand.
Even with the Tunes getting better and putting less stress on the gears, "Do you want to take that chance?"
If the oil pump gears shatter/explode while under full pull the motor will cease!!!! It's not just a matter of replacing the gears!
Newer engines like the 6.2L are built with very tight tolerances, it doesn't take long for the motor to cease without oil.
Unless your trying to get a vendor to state it's not necessary,
I don't believe anyone would state that.
I do believe the chances of something happing is very slim to none if you stick to your Tuners recommendations.
Even with thousands of Whippled Raptors that have not done the oil pump there are just fine! Their also not pushing the HP.
Livernois has been using the fuel pump upgrade for their builds for years now.
The stock fuel pump is good for 550 rwhp with a good Tune. After that fuel starvation kicks in.
B.A.P is a cheaper fix, most Drag Strip Mustangs do both Pump and B.A.P. or dual pumps and a dual B.A.P. unit.
And also their doing a return fuel system setup.
But we're talking much higher HP levels.
Driveshaft and springs is a must. IMHO
Wheel Hop/Axle Wrap, is the big problem with all that HP.
Hell even NA Raptor can tear the rear universal out of the driveshaft with enough axle wrap.
Can't go wrong with Axle Exchange's Driveshaft it has a great track record.
Quite a few of us on this forum are running it.
And is sold by a few vendors here on the forum.
Thanks my Friend!
Always enjoy, and learn from your posts!
---------- Post added at 04:12 PM ---------- Previous post was at 04:03 PM ----------
We do in house installs
-Jeff
I will be in Australia until the middle of February, but should have some time after that.
Quote me a install with oil pump gears, fuel pump if needed and drive shaft.
Possibly Leeann style traction bars?
At the same time we could install my new rear bumper :)
I would need to know the exact start date and length of time for the install.
Thanks,
Arno
mike.s
Well-Known Member
I'm not sure if SVC will order the gears for you. I ordered them myself from Triangle Speed Shop and Addiction Motorsports installed them for me. SVC should be able to install them as well, just don't know if they will order it for you or not.
---------- Post added at 05:29 PM ---------- Previous post was at 05:28 PM ----------
PropDr, do you have a picture of the traction bars you are talking about? I'm looking to have SVC make some for me like the ones Skl3r has on her truck.
MTF
Celebration, Florida
KHC has the traction bars hanging in their show room, I didn't see the brackets they use. But the bars are the same or close to it as Skyl3r is using.
Brandon is running them. I never ask his opinion about them.
PropDr
Eugene, Oregon
I wonder if you could attach a traction bar between the fwd spring bolt and the bottom shock mount, or better a plate between the spring and spring perch bend down/up for a connection point with proper triangulation for the bar?
