So I just read this "weep hole" thing. Let me see if I understand. You drill a 1/16th hole in the charge side?! You create your own boost leak... of metered air?! The argument is that you make more boost than this hole can bleed off? I must be misunderstanding.
so glad you added such a gem to a thread about spark plugs... bravo !!![]()
I was making a joke about the weep hole. After I ordered my 2018 and before I took delivery of my truck, the forum had a “Squachy” goofball that posted weep hole threads every other day.
Having the proper heat range is important for plugs, but you aren’t going to shave .4 seconds off your 0-60 time with a simple plug change. If the factory plugs were way too hot, plenty of people would be having engine problems within 10K miles.
I’m old school (70s 2 stroke bikes) and know how to read a plug. I have installed and pitched plenty of plugs within a few miles based on jetting tweaks alone in motorcycles. I realize the computer controlling timing curves and the fuel mix changes things in my world, but the Ford engineers are not going to spec out a “way too hot” plug for our trucks with the factory tune.
I have always felt that reading the plugs will tell the story of a proper tune and are not performance mods… but what the **** do I know in this day and age.
If you shoot a new tune to a Gen2 Raptor maybe going to colder plug will be the right thing to do in order to handle the tweaks to timing and the fuel ratio.
That said...Please don't drill a weep hole!!!
Yeah I am having a hard time with this being the miracle mod. I have no intention of drilling a "weep hole," but I wanted to figure out what it was when I read your post. I also wanted to subscribe to this thread, so I thought I would comment about the weep hole. My bad. I forgot that this forum bites when you make a mistake.
Fords priority is often emmsions. A hot plug with help with that.
