Security Systems
justvettn
GTA
I have a cheap solution to the alarm problem, stick one of these in your window luminescent indicator and thieves will leave your truck alone, only 12.95 better than nothing Lol!
The Car Stereo Company
here, on frf
haha, never used one, just had it in my toolbox for years, from an uninstall that i did and the customer never came back for his alarm to be re-installed in his new vehicle
---------- Post added at 12:25 PM ---------- Previous post was at 12:24 PM ----------
I guess it would have to go on the front or back glass. How small are they?
about 2"x2"
SrBug
Houston
Hey nosbusa Did you ever got to make the step by step video install of your alarm?
here, on frf
its on back order. i havent received it yet. but when i do, it will be similar to the 9500ci install video. i should be getting it in the next week or 2
SrBug
Houston
can you make one for installing the xpresskit DBall ? im all good to go but i could use some orientation on the wires to be used and the ones not used, thanks in advance!!!
im using it on a Cliff 570.4 on my 2013
SrBug
Houston
im stuck at the keysense connections they both + but one needs a diode (1N404)
BCM--------to-----DBALL
keysense (+)--- to--- Pink/White keysense input
keysense (+)--- to--- diode to Gray/Black keysense accessory output
the only thing that i can imagine is they both go to pin 5 in Black 7 pin connector but that could have been represented in the diagram but is not,
the diagram is made to confuse and not represent its full purpose to display connections
therefore a need to call tech support and not getting it for not being an Authorized Dist.
anyone can help?
here, on frf
my alarm came in yesterday. i will be installing it in a few days, if you can hold out until then i will have some detailed instructions for you
