Raptor Throwing Every Error Message
adllewis42
Seattle
Haven't had this happen to me and I wish I could help but just commenting to follow along with the updates. Hope you get it take care of soon!
FordTechOne
Detroit
Do you recommend that I open a case with Ford Customer Service before it's even seen by the dealer?
Wouldn’t hurt, as they can often assist with scheduling the visit and finding a dealer that has available service appointments.
@FordTechOne and sorry to be annoying with multiple posts, but how do I go about requesting a Ford Field Engineer? Any suggestions or just call ford customer service?
If the dealer can’t figure it out or makes multiple repairs and it’s still not fixed, you can request a field rep from customer service. Their criteria for engaging a rep is based on time down and repair attempts.
allenilly3
allenilly3
Maryland
I got the truck back and the dealer found a loose ground which was causing a communication error and causing the systems to shut down. I was a little skeptical, but to be fair, I did dry fit an Up Down Air controller a week earlier and it's possible I overtightened a ground screw and unknowingly stripped it. It's hard to believe I wouldn't notice that when doing it or when checking the grounds later, but it's possible and makes sense. I also haven't had an issue since I picked it up.
It looks like this one is on me and not the truck. They used oversized self tapping screws instead of rethreading, which I thought was weird, but whatever. Either way, I'm glad it's fixed, but I feel like an idiot that it was something so simple and I may have caused it.
@Booth9999 good call on the diagnosis. I appreciate all the help from everyone.
Rednose
Well-Known Member
Dubai
Glad you figured it out!!!
Now you need to enjoy the truck without having to think about all the issues.
Bowewelding
My power train malfunction could not be figured out on my 2017 by the dealer even with ford engineering help.. asked ford for a buy back and they approved it..it was 4 attempts and like 40 days in the shop. Turning it in this coming week then shopping for a 2020
allenilly3
allenilly3
Maryland
Wow. Sorry to hear that but happy you’ll be in a new Raptor soon!
JustDennis
Upstate SC
Glad to see you got this corrected. Just had something similar on mine and it ended up being melted wiring on O2 sensor too close to exhaust.
rightway
usa
Sure was interesting and a pleasure to see how everyone jumped on this Forum to give you a helping hand.
Just so I can learn from your experience, there are a lot of different ground points in a truck.
How many grounds did they work on?
What was the actual bad ground point that caused the failure?
Thanks
