Raptor Throwing Every Error Message
David Nelson
Dexter, Oregon
Just got the Ford Pass alert. This is really strange. Can’t engage 4x4, can’t engage the parking brake, Sync system and nav was unavailable. Definitely seems electrical based on the weird errors.
I was splashing around in puddles around the dunes earlier but nothing was thrown at that time.
Just had that one show up, did not reduce power but threatened too. Was driving in 4A cause of rain. It dried up so switched to 2wh and a couple of miles down the road that error popped up. Drove home and I have the Bully dog tuner so I reset the code and all is fine. For now at least.
allenilly3
allenilly3
Maryland
Sure was interesting and a pleasure to see how everyone jumped on this Forum to give you a helping hand.
Just so I can learn from your experience, there are a lot of different ground points in a truck.
How many grounds did they work on?
What was the actual bad ground point that caused the failure?
Thanks
Sorry for the late response on this one. There were 2 loose grounds that had stripped screws. One of them I removed previously and must have stripped out (still not sure how), and the other was never touched. The ground screws were towards the front of the engine bay on both the left and right sides.
allenilly3
allenilly3
Maryland
If it happens again, check the ground screws in the front of the engine bay. Mine looked fine and didn't move with a slight tug but they were my issue. There are 2 screws per side if I recall.
Next, I would check the rear speed sensors to see if any dirt or water got in there.
After that, take it to Ford lol.
Booth9999
Idyllwild
If your wheel speed sensors are good then it more than likely a ground issue.
FordTechOne
Detroit
Tuners can induce plenty of issues; the factory calibrations are extremely sensitive to parameters that are outside of the norm. Remove the tuner and re-evaluate.
96,966
60,909
53vodich
Latest posts
