RS4
- Joined
- Oct 8, 2015
- Posts
- 65
- Reaction score
- 57
Long story:
Replaced main radiator 2 years ago after seeing white smoke from the tail pipe. SC radiator still good.
Recent: Check engine light twice: one was SC Gaskets that were shot. Other time was O2 sensor. Replaced entire rear differential which was annoying with only 55k miles. Maybe too much wheel hop over the years. Need to get better springs eventually! Had to replace all the heater lines which was weird. Need to rebuild the shocks next.
So back to the radiator. Flushed it 3 times and still oil in the radiator. Mechanic checked engine block and head gaskets and seem solid. Main oil is not contaminated and it clear thankfully. Engine temps remain stable but we can’t figure out the problem. Maybe just replace the heat exchanger or coolant tank? Gonna flush it again but hoping i don’t need a new radiator. Mechanic says to keep flushing it and it’s okay to drive as long as temps are good. I frantically check the oil to make sure it’s not contaminated but it’s good.
Any ideas and wtf is with this crazy maint on truck with 55k miles? Bought the truck 7 years ago with 3k miles.
