Diverdown3
As mentioned in original post, I have no way of knowing, hence my urgency to have the change and analysis done quickly. Although the analysis summary and numbers suggest it was changed at least once, since their 10R80 averages @32k nearly match my 84k numbers.So to you knowledge was the trans fluid changed prior to you? Because if not , your report would suggest that the OEM spec is “somewhat” justified.
