Valve and Timing Covers
ThreeSixT
San Diego
My 2018 with 76k miles is at the dealer for regular oil change and some other minor stuff. Inspection revealed oil all over the engine bay due to a cracked valve cover and cracked timing cover. Service tech says this is a known issue on the 3.5 due to heat stress over time. Had no indications of oil loss via alerts or dripping where parked. Anyone else had this issue?
Also fought Ford for two days to get phasers replaced, after previous dealer refused to cover it twice during the campaign two years ago saying symptoms “weren’t bad enough” after the PCM update. Phaser rattle now getting worse by the day, so Ford finally agreed to cover it even though no longer under warranty.
BoostedToy
Hudson, WI
Timing cover is an expensive job with the labor cost involved. If it’s a seal issue with the timing cover and the oil leak is small (are you losing measurable oil when checking oil level?), you may want to just ride it out if it’s a nuisance issue versus something that potentially would cause mechanical damage. Once you open it up, you may as well do the phasers as well. You’re probably looking at $4-5k on that job.
Badgertits
Ma
My 2020 was getting spark plugs replaced & noticed oil pooled up on valve cover small crack drivers side (I think) @ 82k miles just replaced it outta pocket since I was already putting $$$ into refreshing the suspension
Independent shop charged me just under $1k for it which I didn’t think was terrible
