Got 99 problems and my Gen 1 is 1
New recaros
Colorado
This is what I see after a 5 mile drive and idling for about 15 mins.
And this is what I see after holding the idle at 1300Rpm for about 3 mins. Nothing close to setting off a light, but clearly missing more on cyl 6. I have swapped plugs, coils and wires twice and nothing new. Lt Fuel trims as low as -8.
If you look at you first data chart and compare the misfired cylinders to the firing order you will find your answer.
It shows every other cylinder is misfiring.
2011reptar
okc
Okay, so I guess this is “solved,” and the first shop was right after all.
I drove two more Gen 1s today and they both had the same shaking shuddering idle mine does. I only got to hook Forscan up to one and it also produced some minor misfires, so that checks out to be “normal” as well and is why ford has a threshold before it sets off a light. One only had 30k miles and was a 2014, one had 88k and was a 2011. I guess it is truly the cam profile of the 6.2 specific to the raptor. It’s the only difference between our 6.2 and the 6.2 in super duty.
I will be looking to a tuner to raise the idle a little so it doesn’t dip so harshly as I’m just not comfortable with it.
I can definitely live with the shake, I just thought something was wrong with the truck, but lesson learned!
I will update this thread if it turns into anything else as I’m still getting a weird occasional pop from the driver side exhaust that makes me think it’s running too rich. But anyway, thanks everyone for the suggestions and advice!
slade8
Nevada
The first thing I noticed was that studder or shake in the seat and floorboard at idle when I test drove my used 95k mile 2014. Among many other things it was my biggest concern after reading about valve spring failures. I had 5 days to return the truck for a 100% refund so during that time I took it to a 20year ford mechanic who now runs his own successful shop. Scanner like you said showed nada. Mechanic sat in the truck and also acknowledged what feels like a misfire-studder. However he looked me in the eye and said, "sounds normal to me". On the way out he agreed a warranty would be a good idea for the transmission while he had another 6.2 transmission replacement in the bay next to mine. I bought a warranty thru my credit union but now that I have gotten used to the idle I seriously consider canceling it and using the money for the new cams, springs and braces from livernois. I recently put a tune from 5star in so I will check the idle issue again. I've gotten used to it and have to tell my brain to let it go. I appreciate all the troubleshooting and posts you made. It's nice when someone else checks some boxes when your own list is already long asf!
2011reptar
okc
I hope it helped some! Please let me know if the tune helped at all.
slade8
Nevada
I loaded the 5startuning 91 octane performance tune tonight. The idle miss fire or shutter-shake you feel in the seat and floorboard is still there. Unfortunately, this rev-x sct programmer doesn't indicate the max and minimum rpm when in gauge mode. I have to eyeball it and the idle rpm is jumping up and down between 629 min - 660 max. Mostly it's running 640-655 but you can't actually see the exact change in rpm when it seems to miss fire. The 91 octane tune feels better using the arse dyno. The engine purrs on the road and the upshifts are much smoother. The tune seems to keep the truck in the best gear and for the right length of time for the best performance imo. It's a lot more enjoyable to drive now. So either I am getting used to this idle or the tune has made it less noticeable with only 40 rpm in movement? I do not know the idle rpm range prior to the tunes or any of the other things I tried such as crf and cro 505 treatments last month.
2011reptar
okc
Interesting. Seems to have bumped it up some then at least compared to mine. I average 580-620rpm at idle give or take 10-20. Nice to know it has given other positive comforts! I’m not a big 5 star fan from a bad previous experience, but it’s been about 5 years since that happened.
slade8
Nevada
Altitude is 2400ft coolant temp was 210f air intake temp was 110f at idle. So not sure if they bumped up the rpm or if the ecu is doing it on its own. Cai and catback is all this has that might effect a/f but I don't see why the ecu would change the idle for it. I was leaning HP tuners but just don't have the time or the engine upgrades at the moment to go deep. I read on here where a dude complained about stars tune shifting to hard and almost didn't use them. However, that is entirely not true in my tune from them and they answered all my questions along with 30% off. I was also hoping to go local with a cool owner of a serious raptor shop out here but the tuner and tune was going to cost over $700. Though it's probably a great tune and we'll vetted it just didn't make fiscal sense for my current raptor use. ie wax on wax off, drive, smile, repeat.
2011reptar
okc
Welp, my satiation with chalking it up to chasing ghosts didn’t last long - or my anxiety/boredom got to me anyway.
I have opened this can of worms again due to what I noticed the other day messing with the throttle. If I hold the RPMs at say, 1200, I can audibly hear the engine load down a bit then back up, then back down every 2-3 seconds. Similar to when the AC cycles, but not quite as pronounced, around 50-100 RPM difference, won’t ever stay steady under acceleration in park. Still have the 570-630 RPM fluctuation in park at idle that is observable on the tachometer. No engine codes, no performance or MPG differences.
A quick reminder on what’s been done - 16 plugs, 8 wires, 8 coils, 8 injectors, MAF sensor, throttle body with sensor, PCV, purge canister, air filter, up stream 02 sensor. Have done compression checks, vacuum leak checks, checked valve springs. Ran cleaners through the top and bottom end, scoped a few cylinders.
Only thing that’s a little off is I’m getting consistently negative long term fuel trims. Not too low, but around -5 to -10.
Gonna call around and see if I can find a shop or mechanic who’s really Ford versed. Out of ideas completely.
Here’s a quick vid of the Forscan data showing a few things including the RPMs at idle. YouTube video
