put up your dyno results
mudblood
Atlanta
what jumps out at me on this is his comments on under hood open air filters. that section is not likely to be popular here.
He is right on there. I have seen it a ton of times myself. You open the hood on a stock filter and a closed hood on an aftermarket filter and you can see as much as a 30 hp change on the stock set up. The only system that I know of that pulls air outside of the engine bay, that will fit our trucks is the Voilant closed system scoop intake that draws air from the front of the grill. You of course must also purchase the volant closed filter intake system to use this option but it does actually take air from outside the engine compartment. That is about the only product on the market that can claim they use "colder" air. Will it increase power???? That would have to be tested, which to my knowledge has not be substantiated.
Wilson
Wilson
South Dakota
I agree with the open hood on a aftermarket would be worse. I have an aFe I'm new to all this so it's just my logic of thinking. I did not shut the om cold air under wheel intake so I'm hoping with the hood shut I'm not taking in all the hot air but making it breath whatever is easiest is where your air is coming from so where is that? probably around the top with only a bit being pulled up. how would one test this theory?
also what is better breath ability or getting that tad bit cooler air?
mudblood
Atlanta
Frankly from what I have seen the aftermarkets are no better at pulling cooler air than the stock unit. The only one I know of is the above^^^
Wilson
Wilson
South Dakota
IMO putting on a hose to draw are from outside the engine bay if It's not bigger than your tub going to the intake it's too restrictive. cold air is important but is it more important than flow. I don't think so as long as you are getting as much cold air you can with volume. meanings you might get some bay temp air.
mudblood
Atlanta
You would only pull in enough to match the diameter of the tubing. You really don't need a huge outlet for that. Keep in mind the air is forceably PULLED into the intake. I just don't think, without a tune to take advantage of an aftermarket intake, you will see little or no change in power.
Wilson
Wilson
South Dakota
I'm referring to this looks more restrictive than the tube going to the intake. more air would imo be better than not enough cool air. ? remember I have know idea what I'm talking about I'm just using my logic.
mudblood
Atlanta
I am certainly not trying to sell Volant products but the diameter of the tubing is the same as the tubing going to the TB.
