Post Your Wheel and Tire Pics !
Lvrkight6481
Las Vegas
This is the setup i want. 18x9 Fuel Vectors with 35x12.5x18 bfg ko2's. They sell it either with a +1offset or +20 offset. Should i have any issues with this set up? Which offset should i go with? im thinking +1.
As the last post stated just depends on how aggressive you want to go. Shouldn't with either offset. Mine are -12 so had to do mid perch to fit. But if I had to do it again on this truck it would be the +1.
RaptorJet
Appreciate the feedback fellas! That's the exact information I was looking for.
A.I.I.Raciing
Dezert 8MYMNEY
Costa Mesa
Anyone have Fuel Trophy wheels and 37's(BFG A/T) on mid perch?
Curious if there's any rubbing or not with this configuration
oplersx
British Columbia
For guys with method wheels, do you guys have to install rings? To get them hub centric?
通过我的 HUAWEI NXT-AL10 上的 Tapatalk发言
FP Forged
Justin
Reno, NV
Roosts are hub centric. The other wheels cannot use hub rings unless you don't run a center cap. The center cap pushes through from the back so you can't have the cap and the ring. I had some hub centric caps made a while back for a different wheel that used a push through cap. They came out pretty nice.
oplersx
British Columbia
Already bought the NV. Steering wheel was shaking a bit at higher speed. The shop balanced the tires again this morning seems fixed the problem. But if someone can make ring/cap for NV, I will definitely get a set.
