Perch Mod Discussion
Mid perch or no?
  • Total voters
    426
jrodrg
Niagara Falls,NY
Great video! I'll add ths mod to the list...... I was hoping I wouldn't have to take the suspension out of the truck for his. A+ guys!!
iHaveGas
San Jose, CA
So sad :( this video was spot on and was supper easy to do. That is till we were trying to move up the blue clip. It would not budge at all and yes I did have out the small set screw. It maybe that there is corrosion or grim under the clip from all the off road trips. We tried using a board and jack to push the clip up and tried to clean around the shock but still no luck. Anyone have any ideas?
ruffstuff
Take it to Busa's friend in Milpitas? :wink: :emotions122:
Madcowranch
Genetically Modified
OK
Can't you just set a screwdiver up against it and tap it with a hammer?
It's a snap ring if I recall. It's just galled together. Maybe a little WD-40.
iHaveGas
San Jose, CA
We tried that and the wd40. It's not the snap ring it's the blue ring with the "SVT" logo that is over the snap ring.
Madcowranch
OK
Oh. In that case I don't know. Maybe hit it with some PB Blaster and let it sit overnight?
Nick@Apollo-Optics
Thanks for the video RPG! You saved me $300!
One question: Do you still need an alignment after doing this mod since you didn't remove the shock? Or does it still need to be changed because of the different height?
Wilson
South Dakota
you don't have to it will just were your tire's faster is it happens to be out. you know how to tell if it's bad let go of the wheel on a flat surfaces if it tracks straight good to go until normal maintenance. If it pulls it should be looked at. It will pull slightly to the right if the road has a good crown. also pay attention to wind as that will push the truck across the plains.
