Driver Side Valve Cover Has Oil on it.
MarkM98
St Louis, MO
I replaced the spark plugs on my Raptor today. When I pulled the engine cover off I noticed that there is oil sitting on the valve cover. It was above the coil packs kind of close to the intake runner for the first cylinder. My question is, has anyone here replaced the valve cover on their own Gen 2 Raptor? I have found only 1 video on YouTube of a guy replacing one on his Gen 2 Raptor, but it was not the best on showing what all needs to be removed to just get the valve cover off. I’m almost thinking about taking it to the dealer to have them mess with it. I would rather not spend that kind of money for a valve cover. Does anyone have any good suggestions?
nikhsub1
Los Angeles
I have not replaced a valve cover yet but the driver side leaking is super common on the gen 2s... I think the part is only like $80 or so and apparently the issue is rectified with the new part but I'm not positive about that. Can't help with the video, sorry.
downforce137
In Diana
pretty common, theres a service bulletin to replace the valve cover as a crack develops and it leaks in the top front..
did mine myself in about an hour start to finish last year.. you will need to pull the upper manifold, so may want to get the gaskets for that, but the valve cover kit comes with everything else..
