okay motorheads...
Here is the follow up...
I am having issues during cold start up.. the truck runs like hammered ass (sounds like it is cutting out and stumbles) until it warms up, then it runs fine.. There is still a slight smell of burning antifreeze, no fluid loss, oil has been changed. I have returned to stock tune to see if this issue is still there. And unfourtantely it still does it.. I am going to but some miles and drive cycles on it and remove CAI before I return to the dealer.
Anyone have any ideas?
NO codes
All intake hoses are tight
Could it be a vaccuum leak? The leak may cause the nearest cylinder to run leaner than the others. The ECM will indeed richen up the overall mix in an attempt to bring the excess oxygen in the exhaust back to the appropriate low level—but that will force the other cylinders to be too rich, which may cause a whole menu of issues—misfires, unstable idle, etc
But the ecm runs in open loop during start up and ignores the O2 sensors until operating tempature is reached.. When it goes into closed lop it runs fine?
Bad mass air sensor?
any ideas would be greatly appreciated!
